When we were on our European trip, our tour guide told me since EU is established and ppl move freely within the EU, most accidents happened on the motorway was cos some poor old bugger from the less advantaged part of the EU was driving his rattling old Lada in the left/fast lane (they drive on the other side of the road than here) and get rammed up from behind by those Porsche/Audis/BMWs/Mercs...
our bus was always on the 1st (right) or middle lanes doing around 130km/h, and often we have cars thundering by on our left at 160km/h, with occasionally super ones like the RS4 or Porsche goes ballistic probably over 250km/h no worries.
apparently the Bracks government might use this example to enforce another thousand of speed cameras in Victoria.
same administration really... they are both as obsessed as each other in making money from driving/parking infringements....
i wouldn't even mind if they'd just admit that its blatant revenue raising.... its the assumption that we are all too stupid to work it out that gets me!
That is a massive number of cars, but no-one seriously injured. Some of the cars looked like they'd taken a big hit too. Was it due to well engineered, safe cars, well designed safety features on the roads itself or just pure luck?
The tow truck drivers of the area would be pretty happy and smash repair places too. Insurance companies on the other hand...
awesome! that's great news.... i'm so excited that there will be more speed cameras! all this money was weighing my wallet down anyway!
u know that there r gonna be another 35 cameras in vic and another 3000 hours a month from mobile cameras
yeah, i'm gonna pull double shifts 7 days a week and just donate my money i think.... cut out the middle man so to speak
(btw i only have 1 speeding fine in the last 5 years and that was for being 4kph over...)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
