So... sitting back looking at my car i though there are some damn cool parts about it that you don't find on many cars, these parts are numerous and interesting... but whats the COOOLEST part? So a poll is afoot!
Lets take a couple of days worth of suggestions to go in the poll then we'll vote.
I'd like to put forward;
1. The bifolding centre consol - so rad!
2. Folding back seat leavers - just damn handy!
3. Falling rear windows - looks super summer cool with all glass down
https://www.sau.com.au/forums/topic/280378-coolest-partbitthing-on-the-stagea/
  • Replies 43
Posted Images
the popup screen. ohh and heated seats. and the reverse camera.
I do like the pop up screens! heated seats and reverse cameras are for mums though :thumbsup: haha think cool wall on TopGear, doesn't need to be functional much or pretty just COOL :thumbsup: each to their own though ill pop those ones on the poll :yes:
Auto-closing boot. Not sure if its the coolest but its worth having in the poll.
note that the rear windows in the M35 dont fall down like the C34 does. they stay level and only open half way. I prefer the C34 way, just gets attention from people :thumbsup:
I do like the pop up screens! heated seats and reverse cameras are for mums though :yes: haha think cool wall on TopGear, doesn't need to be functional much or pretty just COOL :thumbsup: each to their own though ill pop those ones on the poll :)
is someone jealous they dont have these functions??? :thumbsup:
My favourite feature is that it has no traction control, it's more tail happy than my old man's '06 Holden VZ ss ute.
I can't stop it from getting the ass out on wet days!
is yours RWD? I thought the RWD stageas did have TCS.
The AWD ones will step the back out round a corner in the wet/dry if you plant it but in a straight line good luck getting any wheelspin, wet or dry.
how about "so many different configurations/options" on the list. is that a feature?
This button is the coolest part on the Stagea - it can do SO many things :thumbsup:
Lol, if you read the earlier post regarding that button!!
Nobody mentioned twin sunroofs!!! Not many cars will give you that one. :thumbsup:
+1, +1, +1 :thumbsup:
hmm, I'll take the AWD anyday!
Coolest feature
Turbo blowing up :yes:
the car forces u to mod it
YES!... but where does it end?
I didn't realise that when my turbo blew up, my car required so many thing to make it "run" properly :thumbsup:
I'm for the motorised boot lid. Oh! and the turbo.
Doesn't everyone love the self closing boot?
What about the dual opening rear (get your minds out of the gutter Stephen/Iain/Me) - window and door!
What is the story with the auto closing boot, how do you know if you have that? Is it an m35 thing?
I would like to add the auto dipping rear view mirrors and the bose sub in the spare wheel.
Oh and just the other day i found the hidden cup holders for the rear seats under the middle of the rear seat.
afaik it's not standard in the m35.
The dual opening rear is the main reason I got the car.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
