Hey Ben
Did you grout fill your block?
If so any issues with cooling on the street
Ps luv your car by the way
Na mate just a standard N1 Block, didnt get it bored for the JUN 2.7 Stroker, Got some custom CP pistons made up in exchange. I would only grout fill the block if your gona run methanol..
Here are the runs from townsville, some people can watch them and others cant. ill be home from work tomorrow and will upload to youtube.
Ben do you still have that moroso breather tank for sale. Actually lookin at going opposite to you and moving my dry sump tank from the engine bay to the boot. I'll need another breather back there as my current one is shared between the tank and engine breathers.
Na mate, We used it on our dry sump tank. Run a breather line from the front into the boot.
No probs. I'll get something sorted. Thanks anyway.
On a side note would you guys be keen to run at the Gambler Shoot out on the 6th of October? A mate of mine is running it at palmyra. Just check out the details at www.gamblershootout.com if you'd be keen to run some heads up and sort some v8 egos out in your own backyard. Minimum 1000 dollars prize money per class.
Hi Guys,
We are getting the car ready for the Jamboree, Any advice on what suspension setup we should be running? Currently running +0.1 in the rear toeing straight, and front is -1.5 and toeing in 1mm, thinking of changing the front to -0.5 Any Ideas?????
cheers Ben
I went backwards with running + camber in the rear. My final settings were around -.5 rear camber, slight toe in rear, but my cradle had a few tweakes aswell. Front end was -1.5 camber and a fair bit of toe (to minimise the torque steer). I also removed my rear swaybar from memory.
Cheers
J.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
