  • Replies 340
Posted Images
Lol yeh that maybe true, but at the end of the day its a toyota! Nuff said! Probably just me being a true nissan follower.
But to be fair we used to race with a bloke who had a soarer and it was a quick car!
Ridiculously quick, and very pink. I wonder how John is these days?
He made a rare appearance about 8/9 months ago driving a stock looking black manuel chaser.
Still went sub 60 seconds around the sprint track at qr.
Havnt seen him since. Pity. He's a genuinly nice bloke.
sure can, guys tow fat soarers with soarers on hire trailers, so I should be right being that the skyline is about 250kgs lighter than a soarer :P
Be very careful, check that the trailer has enough weight available to hold the r33!!!
Yeh John is a great guy and a funny character.
Yeh Noddy, he had some health issues a while back and got onto the fitness bandwagon and I believe he has been doing it ever since. He may return back one day! Also, to correct myself he had a pink chaser, not soarer. My bad.
Edited by r33_racer
FINALLY a pic...
haha
paint looks NEAT on it man! you should mod the tails ;-)
clear out the bottom half, and red tint on the top
like this yeah?
now... more pics =)
EDIT - forgot to say glad to see you bought it - i didn't think you would lol!
enjoying it?
Edited by Mr Eps
FINALLY a pic...
haha
like this yeah?
now... more pics =)
enjoying it?
thanks mate, Yeah it drives great...dare I say better on the street than any skyline ive been in.
if you put ghey lights like that on it you will be banned from sau.
lol
no tail light mods, want it to look stock on the outside lol
Got a bit done to the dirty 30 build over the weekend, rods are fitted to the pistons and trial fitted to the block, need to order a set of bearings so I can check clearences then i can assemble the bottom end.
Slacker.... :blink:
It always take longer...put it in then modify dump pipe, intercooler piping.... Stupid RB30's!
It will all be new stuff, Im just hoping I can fit the w2a cooler in the engine bay lol
i can give you a hand with the in/out operation if you want?
Cool, ill give you a hoy If i need a hand :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
