From the recent thefts/scratches on some SAU cars parked out in the driveway/street, I was thinking what I could do to protect my car.
Even though my car's usually garaged sometimes I have no choice but to park in public, unsheltered areas when on holidays for a few days eg., snowfields.
I stumbled across these car covers that have grommets in the bottom so you can loop a steel cable through and lock it. Not only do they protect your car from the elements, but also act as a deterrant to the casual thief/douchebag who keys for fun, and also means that your expensive car cover won't be stolen. Sure they won't protect against someone who is determined to damage your car or has bolt-cutters, but it helps.
The best I found was from a UK site with car covers tailored to our Skylines, but the version which somes with locking kit is an insane 139 pounds ($280 AUD) before delivery.
http://www.coveryourcar.co.uk/store/produc...=288&page=1
No other site has fitted covers for the R32-34s as I guess they weren't really imported much into those countries. The cheapest I found was from a US site on eBay. I guess our cars are the XL size. Would be about $100 AUD including delivery. Has anyone bought any of these covers are has heard anything about them???
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT
Cheers.
https://www.sau.com.au/forums/topic/281173-lockable-car-covers/
look around. I sold my factory R32 cover (which locks into the boot and straps up so no one can run off with it) for a hundred bucks or something a couple of years ago. there should be a few floating around or some for sale from japan.
Good idea. Looks like those parachute arrays for drag cars lol.
Where did you buy it from?
If it's expensive, I think I would still prefer the cable-lock method as it prevents people lifting the cover up and smashing your windows to get stuff inside.
i had one for my old car, just basic one from Super Cheap, windy night i'd be sure to find it on a tree or somthing, and wasnt water proof, spent all the time washing the car, put the cover over it, and it just looked like shit in the morning.
would love one for the Stagea
Unless you are a known child sex offender, usually people smash your windows to get at something inside.
The car cover I guess not only prevents people seeing what's inside, it also makes it hard to steal what's inside. After smashing the window thieves need to cut a hole in the cover, etc. Most casual car thieves want to be in and out as quickly as possible while your alarm is wailing. I think it's a good deterrant when they have to go to the extra trouble to find most likely an empty car.
personaly i think those covers would make people more likely to do somthing... because they will think "oh this mofo thinks this cover is going to protect his baby" bang he kicks your door in..you dont know how some idiots think.
agreed. I'd say there's more chance of someone kicking your panels for shits n giggles if you're in the area where smash and grab guys roam the streets.
alternatively if you have more than one spot outside your house, put a few of these up as decoys.
http://www.geekologie.com/2007/06/car_tent.php
Funky's car cover is a Nissan factory accessory when the R32 was released. You would need to search yahoo auctions and try and find a second hand one floating around. Although i believe they are quite rare.
nissan oz can order in r34 covers from memory. 32's might be a bit too old tho.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
