Hi Everyone,
I am looking at upgrading my fuel injectors on my R33 (Series 1) RB25DET and not sure whether to go for the Nismo 555 or 740s.
Is there any disadvantage of using the 740s, even though my current application doesn't come anywhere near using their full potential? Why I am asking this question is that the 555 and 740s are similarly priced, and I thought that rather than buying bigger ones in the future, I would get them now.
Any issues regarding idle, drivability, fuel consumption etc?
Relevant supporting mods are:
-Power Intake
-Z32
-Nismo Fuel Pump
-Power FC
-3" Exhaust
-FMIC
-EBC
Thanks!
Peter
Edited by Peter
https://www.sau.com.au/forums/topic/281288-nismo-555cc-or-740cc/
Well what future mods do you have planned?
You dont even have a turbo yet by your mod list... 550's will do well over 300rwkw, so unless you want more, dont get 740's.
As for economy - you dont own a modified turbo car, and then worry about how many km's to a tank
Have to agree here. You would stick with the 555's if 300kws is where your headed but otherwise the 740's if your going for a monster that can't put the power to the ground anyway. 350kws or over is just stupid in a street car so decide now where your headed. Though 740's would come in handy should E85 make a big entrance to fueling in the future.
740's are a little more difficult to tune but if the tuner knows what he's doing should achieve a good result.
I have got 740cc's running in my car at the moment.....New turbo is on its way and only looking to push about 270rwkw or so.....
The only reason i got my 740cc's was because i picked them up in fuel rail for $600 delivered....and 555's were at the same mark....it doesnt really hurt having bigger injectors well 740's compared to 555's....if you can afford it then 740's are a good investment as you might wanna chase up more power in the future....do as it suits you mate
740's
i'm pretty close to running out of puff on my 555's with 320ish rwkw
550cc Injectors at 3bar base pressure will support 350rwkw on pump98 (BSFC=0.55) - so I would be checking your fuel flow or the tune or your regulator!!!
550cc Injectors at 4bar will support 400rwkw on E85 (BSFC=0.6).
Can you see yourself making more horsepower than this???
I would always select the samllest injector for the required horsepower in allmost all situations.
My opinion only , if the price is the same and there is no real disadvantage , the 740's leave more possibilities open .
The Nismo 740 is a single pintle injector with a four hole wafer in front of it so the spray pattern is supposed to be very good for an injector that's twice the size of the std 370's .
To me going this way means you have the capacity to make high power outputs with all of the rest of the fuel system running in factory type regulation - provided the fuel pump can keep up . Won't need adjustable FPR's and it can all look factory standard .
I think the real question is can the engine management system run largish injectors and have fine control of them .
I think it was Sk that told me the computer has to have a fair amount of processing power to have fast accurate control of injectors particularly at light loads and lowish revs - normal round the burbs stuff . People say PFC's cope fine with them .
I bought 555's and then 740's because I got interested in the possibilities of E85 - still in their boxes .
Cheers A .
Thanks for all the replies...I think discopotato03 summed up my question better than I originally asked it...
At the moment the price difference between the 555 and 740s is $6.27 per injector or $37.62 for all six....buggar all really...so my way of thinking is that if I can get bigger, for basically the same price - why not?
It was mentioned that the 740s are slightly harder to tune...are there any other disadvantages?....(because besides that, people seem mixed in their views - some people say go for the smaller injector - why?)
If my car will drive basically the same with the 740s or 555s, I might as well go for the 740s as it leaves more possibilities open in the future...
I am more than happy for alternate views...
Thanks!
Peter
Edited by Peter
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
