Hello,
I have just been told that I have to take out my Microtech ecu (cops) and was looking at the nistune option. What my question is are they a good option to go for knowing that i will be checked for to see if my ecu looks stock. Is there many of them being used. my car is a r33 s2 (auto)
Mods so far are FMIC, full exhaust, splitfire coils, did have a Eboost2 boost controller but also had to be removed & a Hypergear hyflowed turbo. I am looking to get back to the power i had before when i had all my parts in. Any help with this will be very helpful :thumbsup:
https://www.sau.com.au/forums/topic/281946-nistune/
  • Replies 46
Put the standard ECU in, get it checked over (defect cleared?) then put the microtech back in?
Do cars in victoria regularly get checked for aftermarket management? Or is it really obvious (hand controller visible?)
Was going to say with the mods you have the nistune would probably be a better option than the microtech. Sell the microtech should cover the costs of getting the nistune installed and tuned.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749288
Had my gtr for 7 or 8 year and have never been checked :happy:
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749441
It isnt? I thought it still was in Queensland? lol well thats a load off my mind
They are aligning with the national standard in 18 months but if you get a blue plate now and it has written there that you have an aftermarket ECU, in 18 months when they introduce the standard, you will be ok to keep it. Anyone after the standard is introduced will not be able to have an aftermarket ECU fitted.
There is currently no emmissions testing in QLD so for the time being we are safe. I got this info from DOT and the guy who writes my blue plates.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4749582
Its funny how cops can find and EPA you on a high flowed turbo, which they are just identical looks to any other stock turbos. I also had a customer who got defected in Vic over a high flowed GTiR turbo that we worked on. I really believe they have X-ray eyes or some thing to looking through metal housings for bigger wheels.
Nistune is good and cheap. You can get away from most of cops with it. But I don't think Matt have made one for R33 yet. Most people I know is running off a R32 ECU with modified loom.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4751777
Nothing available for R33 yet, as far as I was aware it is plug and play with a 20 ecu, its just that you loose the variable valve timing, but I think its only series 1 that might be plug and play as series 2 has the ignitor in the ecu where the Rb20 does not.
https://www.sau.com.au/forums/topic/281946-nistune/#findComment-4752189
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
