  • Replies 44
Hey guys, tryed looking for the topic in the SA section with the powder coaters but cant seem to find it anymore, does anyone know any good Cheapish power coaters in adelaide? im on a budget at the moment so ill be spending around 150-200ish maxs.
Marshall Powder Coaters
16 Wingfield Rd, Wingfield, SA 5013
p: (08) 83471241 f: (08) 83474214
in fact, a basic google search gives you the info your after. youll just have to ring around for quotes!
AAA Powdercoaters in Losdale - haven't used them yet, BUT they do their own blasting and coating, whereas many will outsource the blasting making it more expensive. Have been quoted $40 per rim blast & coat :whistling:
these guys are the guys to see tho:
Edwardstown Powdercoating
9 Lagunta Ave Edwardstown SA 5039
ph: (08) 8277 9500
very professional, great work, and the cheapest when i called around. the guys down there have a few imports for themselves, last i checked i think one had a S7 RX7 and the other a 34 GTR if i remember right. good bunch of blokes, the sandblaster guys they were using for my wheels f**ked up, but instead of the powdercoaters wiping their hands clean they went out of pocket and made sure i went away happy, even though it wasnt even the powdercoaters fault they went missing.
i have reccomended quite a few people to these people and they have always walked away happy with the results, and extremely happy with the price.
maybe not a great example as these were dirty at the time but heres my GT-P's i got done black:
here's the GTR wheels done white:
Can't recommend Les Thompson enough!! Had 2 sets of wheels recently sandblasted and powdercoated (centre's only) and I was charged $25 per wheel...I had to ask again as I thought I mis heard the price. Extremel happy with the end result and customer service, wheels were also finished in less then 1 week.
Les Thompson : 0412795818 or : 83511133
33 Kent Rd, Keswick (near busfrieght)
**both sets of wheels will be for sale shortly aswell.
Edited by ISC-Performance
Is that price just to blast and coat centres? Reason I ask is if it would surely be different for a complete rim as the surface area would easily double if you're coating the inner of the rim, not just centre spokes.
yeh it is, cheaper for just centres.
My grandfather knows a good bead blaster and poweder coater... But cbf getting the business name and number lmfao!
And what was the point of posting that? just trying to improve your e-penis post count? :/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
