I called into ATP today for a highflow after removing my turbo, what a job. There are a few bolts that were obviously never meant to be accessed without the engine out, took me around 3 hours.
Kip the owner of ATP is a top bloke, easy to talk to. He helped me choose the right combination of wheels for the power I wanted and showed me how they go together with another one he was doing at the time.(thanks Jason) I would love to go back in when the assembly is done on mine just to say "I rebuilt it" :)
Suspension is next, I have a shiny new set of BC racing coilovers to go in, from just jap. I tried to upload a pic but no go.
https://www.sau.com.au/forums/topic/282170-highflow/
So where are the details and pics of your turbo?
Secret mens buisness apparently, no cameras allowed. :( I did ask for you.
I was going to get some pics of the car too, but theres not much of it left.
Heres a pic of the coilovers tho.
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752356
10/8? thats gonna be VERY firm you know?
Yes, but no.
Most M35 suspension is over 8 for both.
I know the Nismo's have over 9 at the rear.
The only suspension I can think of (off the top of my head) that is under 8 for front and rear are the Kenstyle which are lowered and around the 5 mark - which is waay too soft imho.
Edited by iamhe77
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752411
i guess its a heavier car, and you might be able to adjust the dampers to 'soften' the ride a little.......
i still think its gonna be a teeth rattler and a boob hurter. my yellow s15 had effing hard suspension and no girl would get in it as it really hurt their boobs. you dont wanna risk that in your shagin wagon :(
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752435
I went back to kewish today just to stop you buggers whinging. The box is empty. :P and so is under the car. I will get some secret pics from Kip's workshop if possible. He rang me today and talked me into a larger again turbine wheel, bugger, I hope theres not too much lag. should be good for 250 or more, if I want to go that high. The box will handle it at least.
https://www.sau.com.au/forums/topic/282170-highflow/#findComment-4752869
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
