Thats not good! Didnt you notice that before the tune? Thats the last thing I want, being all happy to get the car into a better shape only to find out something is wrong with it and require fixing prior... Hope you get that fixed soon.
I found a 2nd hand pfc locally and just bought the boost kit from access (cant be bothered waiting 1 month for it to come from japan). Bought Catco 3" and HKS front pipe arrived today... look damn good!
Hopefully everything will be here by Tues and I can go for tuning on Wed if not the following week. :rolleyes:
  • Replies 71
Posted Images
I noticed it Sunday and thought WTF? I guess I was in denial. It's only a recent thing. They didn't sort the clutch out entirely either so all round a bit of a fizzer. :rolleyes:
Keep us posted on what happens with you Brandon.
Not good that the turbo shat itself, at least it should to be too horrendous to have it rebuilt.
I honestly feel my car performs better with the M's pods over the airbox (which makes sense when you take into account the surface area of the filters and the mouth design of the pods against the stock box). Critical thing is the get pods separated from the hot engine bay.
Beat you to it!
Bought the dumps and rescheduled the tune the week after I installed both front/dump pipes.
Good stuff!! :D
They're still f**king around with my clutch anyway. Not happy:
http://www.skylinesaustralia.com/forums/Cl...13#entry4780913
yea... clutch is another tricky 1. I dont know how well mine's gonna hold after the tune. I was told it should be fine until 350kW.
Tricky to install too due to multi plates I was told yesterday. :D
Hopefully it'll hold out. Do you know what it is exactly?
Cool! Mind sharing your full list of mods (e.g. exhaust system, boost level etc)? Buts its nice to see another proven example of having factory injectors running that kinda power. I guess you just gotta becareful when you bring it on trackand make sure it doesnt go over 99% or 100% duty.
i got
Apex'i Power FC
Blitz Dual Stage Boost Controller
HKS Turbo dump pipes & front engine pipe
Metal Race Catalyser
Kakimoto Regu 06 Cat back exhaust system
Tomei sump baffle
Tomei type A camshafts
JUN cam pulleys
Sard fuel pressure regulator
N1 oil pump
Trust oil cooler
Its a stock bottom end, and ive got Nismo N1 (T25/T04B 0.64) turbos bolted on the side of it.
cheers : D
next mods Z32s, Injectors and some sort of better intake setup, havnt worked out yet if im goin pods or a arc airbox.
Great. Similiar to what I've got. Very promising for me :P
Hey just on the Regu 06, have you got it tested? What dB is your system? I would love to know that cause I'm thinking of getting that to replace the 1 I have now.
What clutch are you running?
Nah mate. Havnt had it tested. But it is a very nice zorst system, perfect on the freeway u can sit in the car and talk to the person sitting beside you and if you have anyone in the back u can talk with ease. Normal street driving is great, and when u open her up it really roars at you in the high revs. Best zorst system ive ever had on any of my lines.
And im running a ORC twin plate clutch, pritty good so far. Grabs up really well, has been put through many 6k launchs. Fairly Noisey but, when the clutch is in you can hear them rattling quite abit, but i spose its the same for most twin plates.
cheers mate
: D
Interestingly I was told by the bloke tuning it that the stock air box will be a restriction when it's fixed, that it should see over 300rwkw with my turbos but the air box will keep it to 260/270rwkw. specifically put it back on as the pods were rooted. Thing is on here we've seen people on here with upwards of 340rwkw with them, so yeah I dunno. :D
R32 one isnt the greatest
R33/R34 - EASILY 350rwkw through the stock airbox.
Aaron34 & Snowman both have stock R34 Airboxes, near on 400rwkw
I have a 32 with stock airbox, 260awkw @12psi and 310awkw @18psi. Its not an issue up to there at least. In fact all intake including cooler is stock.
Nissan looked after us engineering these cars....
:D
Hopefully the QLD charity cruise has someone with the regu06. I'm really tempted to buy that to replace the trust ti-r if after putting the dump/front pipe on it becomes even louder...
Thanks for the info as usual. :cool:
Good to hear, I've heard 340rwkw with the stock R32 airbox also. I would love 300rwkw but anything over 260rwkw is a bonus. Got a turbo (and more importantly clutch - hopefully today!) issue to sort out now anyway. :D
The truth is out... Sadly it made 340hp at all 4 and thats 255awkw. Will post the graph up tomorrow when I've scanned it. Injectors were around 90% so I guess its a really safe tune. Overall although it didnt make what I expected, I'm happy with the response. Its way smoother to drive now.
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
