Thanks man, yeh it handles like a sack of shit lol
but coilovers, a lowered ride height and a strut brace should fix that.
im thinking some upgraded sway bars too, maybe just the rear to cut out that understeer if its not already fixed.
Got a call from andrew today, and he said the car's all, running well minus a small throttle issue that i know how to fix (needs idle air re-learn)
he was getting to tune it either this arvo or tomorro morning, either way, ill have it back on saturday, hopefully with about 250whp to go with it...
  • Replies 236
update: got the car back form hyperdrive and its about 2/3 done, just need to iron out a few little issues.
namely injector o-rings, 'cooler piping (keeps blowing off dammit) and a small boost problem.
it made 212whp on 7psi, on a VERY basic tune, it has almost no ignition timing (less than 5deg across the board)
its fine to drive around atm but needs to go back there in the new year for a final tune once i can fix the issues.
so far (today) ive done the injectors, sorted out some decent cooler piping.
but now is wants to idle at like 2.5k rpm, which is a Stinger problem, caused due to me taking off the IM (and throttle body), so the throttle needs to be re-calibrated, but ive got no idea how to do that, ill leave it for andrew to do...
tune in mid January for a BIIIIG update (videos, dyno charts, etc...)
Been driving around for a few days now, maybe about 300kms in that week, and no issues apart from a high idle from a vacuum leak, fixed easily.
Going on holiday for two weeks down south and taking the Exy with me, 3 nd a half hour drive there and back on highway will sort out if there's any problems or not. all of that is cruising at 100-110kph, mostly under no load, so I can't see any problem arising, *touch wood* ill be fine. I'll monitor fuel economy closely too, hoping for about 10-11L per 100kms, considering I'm not exactly raping it everywhere with it not being 100% and being double demerits. That said, fuel economy was never my goal, I wouldn't have put a turbo kit on if it was lol
Merry Christmas and happy new year to everyone!
This year's bin amazing for the car and me, you guys have helped invaluably with this build, and I'm very thankful. Have a safe festive season, weather or not you believe/celebrate Christmas...
Cam.
  • 3 weeks later...
thanks fellas...
@ munt...
i know of 2 GTs in aus, both of which in NSW, one of which has had some mods and makes 211kws @ all four. through a CVT auto, on 13psi IIRC...
but yeh they're soo rare, only 500 were ever made, AND THEY'RE ALL AUTOS!!! :):rofl:
and theres no hope of a manual conversion kit either, cos the manual gearbox in the x-trails doesnt bolt up to the SRVET's bell housing. unless you want to fork out $$$ for a custom bell housing that is... :)
I have to say that I have never liked X-Trails... But this is one I could live with :(
Nice work, thinking outside the square and doing something that not many other people would even think of... Make sure you keep updating (I wanna see this when it's all finished).
Cheers :worship:
Hey rhys. Yeh things are all good.
Ive got a throttle problem, the fly-by-wire system is f**king around, and it wants to idle @ like 3k rpm, but I'm ditching it and putting an SR throttle body on next wednesday, the last few weeks have been searching around for parts (bracket, cable TB, TPS wiring etc...) Got most of them from trust ol' Ben @ KYP lol
It made 212whp on hyperdrive's rollers with a base tune and 7psi. Ive driven cars with 250+ whp and this feels soo much more than only 212, probs cos ive got 4 wheels to drive, a transfer case and, plus bigger tyres to turn. It's almost quick enough for me, i think 10 psi will be a good number im hoping ill be satisfied then. after i get this throttle system figured out, im gonna up the boost to 10, get andrew to finish the tune and wind in some more timing(providing its not pinging) + clean up the AFRs - they're all over the place...
Thinking of coming along to the next SAUWA cruise if people don't mind, so hopefully very soon after, ill take it down to motorplex and hope for some low 14s or 13s...
just some pics for y'all...
installed some bonnet spacers for a cool look and bit o' heat treatment (yes it does work to get heat out of engine bay)
ripped off that nismo sticker, dunno what i was thinking...
this is that throttle cable i was talking about. its from a GTi-R (FWD SR), the bracket mounts on to the firewall perfectly. and to my suprose, there was a hole in the firewall already (oh joy!) p.s. excuse the cable tie, just needed to secure the cable for driving around before the TB...
[EDIT] the pics are thumbnails, click and get enjoy some fullscreen love!
Edited by turbo x-trail
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
