Just got the prices for servicing from Von Bibra yesterday
10000km - $600
20000Km - $600
30000Km - $2500
Pre and Post race day
Pre race day - $450
this includes
1. Wheel alignment
2. Download of computer information
3. Engine oil level reduction
4. Brake fluid level reduction and bleeding of system
5. Power steering fluid level reduction
6. Aluminum tape over wheel weights
Post race day - $600
1. Wheel alignment
2. Brake fluid changed
3. Download of computer informaiton
4. Top up of power steering fluid
5. Removal of wheel weight protection tape
?? Transmission oil change (cost not covered)
?? brake rotors and pads change (cost not covered)
I wonder whether they mind me taking my RX7 for the GTR trackday instead :blink:
https://www.sau.com.au/forums/topic/282658-servicing-fees/
Considering the 10K service is an oil and filter change with a few "inspections" seems a bit steep to me even when we're not talking trans fluid change...... Would love to know what they charge for oil. I used to supply my own oil to the Subaru service dept, save money and still get a better oil than what they would have been providing.
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4758600
Pre track inspection is not mandatory. For the post
track day inspection, about $370 is for flushing brake fluid. Bugger that. Surely they can't enforce that for engine transmission warranty. That leaves $220 for hooking it up to the computer and poking around under the car. That's what I'll argue for.
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4765099
I thought both pre and post track inspeciton are compulsory?
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4768433
Pre race day - $450
this includes
1. Wheel alignment
:huh:
Umm, why are they REDUCING the important fluids in your car before a track day? That just seems a bit silly to me...
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4768958
:huh:
Weight saving strategy? ha ha
There is probably some method behind the madness. But i would put i in the same bucket as nitrogen filled tyres. Basically a wank for casual weekend warrior stuff.
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4769151
Engine fluid is reduced to decrease oil pressure, as when racing the oil temperature rises and the increased oil pressure could potentially burst pipes
:blush:
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4770309
I would have thought increased oil temp would reduce viscosity and therefore reduce oil pressure. Oil pressure is usually managed by a regulator/bypass system when oil is cold and by engine clearances when engine is hot.... Also how would reducing the oil level reduce oil pressure short of reducing it so far the oil pickup doesnt "pick up". Which I hazard would create a catastrophic reduction in oil pressure. My only concern with reducing the oil level is the risk of oil surge under hard braking/cornering. However I cannot imagine running the car at the H level will create excessive windage that will aerate the oil. I imagine the Nissan engineers looked after that with good sump baffling etc. I'd always erron the side of more full than more empty...I'm sure Martin could shed some light on this topic...
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4770722
Lol do they ever top the oil back up or do they just take more and more out every track day you go to until your engine siezes? Its so stupid that they can get away charging rediculous prices for the exact same stuff that is done to any car for a lot less. I have been servicing my car for quite a few years now and it costs me 1/3 that of what most places want to do simple tasks. Here is a question, do JRM R35's get no support in aus? Like if you need any factory work done will they refuse your car because it was imported?
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4772091
that's where the post-inspection comes in ..... open up the oil filler cap, pour in the oil and voila $600 please ...... i think both Moorooka and GC dealer says they dont deal with JDM cars, but i maybe if ur willing to pay more? money talks
https://www.sau.com.au/forums/topic/282658-servicing-fees/#findComment-4773191
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
