whats similar is that they are auto stags with highflows....... its all the same basic principles / theories.
S1, S2, M35, all stags with the varied stagea features, auto boxes are auto boxes, and high flows are highflows. again a variety in types..... :)
May be the same principles, but... auto boxes are not all the same. The clutch packs in my box are just too small for the power I want to run. Unless you know of a manual that fits easy, I have no choice but to limit the torque output.
I installed the turbo today, also stuck heat shield around the turbo on the firewall as im not running the rear heat shield. Gearbox doesnt look like its going to be assembled untill next week, as the custom clutch parts havent been manufactured yet. ;)
  • Replies 68
look into the 34 getrag.. seriously. or a 33,32 gtr box in general..
from the brief moment i was under my car i'd say it would have to fit.
a custom bell housing maybe, drive shaft, and prop shaft and bobs your uncleeeeeee...
Must people seem to stick with the ball bearing cores when high-flowing, as some have the opinion that moving from ball bearing to bush bearing is a downgrade even if it is high-flowed.
I'd be interested to hear how you find the bush bearing though, just make sure you take good care of it and use a turbo timer or give it a few minutes to idle before turning the engine off etc.
Once I get the ecu remap out of the way and know they can tune the M35 I'll be sending a turbo off to GCG for a ball bearing high-flow. (can't wait!)
Not really necessary Stephen.
All you have to do is take it easy for the last block on the way to your destination.
Not only will it allow the turbo to cool down, but also the transmission, diff etc, which all need to cool as well.
You don't need to worry about the negatives that a TT brings.
Should be fine. If you see how the ball bearing units work you wont be as impressed, much the same as an old bike hub.
I would have gone with gcg if they had been more forward with information.
The car is back on the road after the tune. It managed 200 at the wheels at 14 psi, which is quite respectable I think.
The turbine housing still seems to be the limiting factor and is the hardest part to change so I think that will end the power gains for now. The injectors, pump and regulator would also need changing if any more fuel was required.
Im very happy with the Kewish Automotive rebuild on the gearbox. Shifting is quick and firm at all power levels without any clunking at all, highly recommended.
And I have some mates coming around tomorrow to help me fit the BC coilovers. Hopefully that will sort the handling out too.
Pretty sure Nissan have been using JATCO boxes in Skylines/Stageas since S3 R31's
Try the late 1960's - the 1969-built LHD 240Z had the 3N71A, the 3N71B/4N71B was used from 1970 through to 1988(ish) in a number of Japanese makes and then the RE401-series took over until the end of the RB. I'm sure the current model is a JATCO too!
PS good power Scott - considering flexible engine management is still a bit of a headache.
:rolleyes:
200 killa wasps at 14psi....good result considering I was at 17psi to get 199.99kw's!.......must be the intercooler and wheel size making the difference.
Are you using the standard boost controller or an aftermarket one?
Edited by Jetwreck
3" FMIC piping = less pressure with higher flow
Congrats on powahhh, bloody respectable I'd say. Interested to hear your thoughts on the BC coilovers too.
Cheers, Dale
BC is not buddy club
they are different brand
although i was told that it's the same factroy (not 100% on this)
Buddclub dont have anything for the nm35's yet
ahhh got ya, i assumed buddy club :D
yeah a few brands steer clear of NM35s for some reason......
ASS | U | ME
(mainly because I assumed they were BuddyClub as well) :yes:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
