hey guys
im goin to be doing an engine swap on my r33 gtr, we are putting a new motor in, still rb26.
im just after sum info about what i need to do in regards to register it as its gona have a different engine number. after info about NSW rego.
what info will i need to get off the guy im buying it from?
where do i have to take the car in regards to any inspections or stuff like that?
i realy dont know what i have to do so i kinda need advice urgently
any help at all will be greatly appreciated
https://www.sau.com.au/forums/topic/283084-engine-swap-help-needed/
My mother's '86 Skyline GXE dropped a big-end and we had to source another engine Chris.
I forget all the details, but I think we had to have all the paperwork on
i) who sold us the engine
ii) engine # but not sure about Kms
After the donk was installed, the paperwork was taken to the RTA.
I don't think we had to take the car there at all.
I don't think we had to call REVs either.
My long-term memory is not quite as bad as the short 'Kris'
The best thing to do is when you buy the motor get them to write you a reciept with the engine number, vin the engine came from if available, K's on the car if aplicable, then when you fit the engine to the vehicle go to a place that does blue slips and they fill out a blue slip with the new engine number on it then go to the rta with it tell them you have swaped a motor over and that you want it changed on the rego papers. Hope this helps you
you mite be able 2 register it still if you know sum1 that does blue slips well. but not sure bout that way if you have lost the reciept 2 be honest. unless you still have contact with the person you bought the motor from just get them 2 write up another reciept
Yep as everyone said, RTA wont accept details unless you can prove YOU PAID for it...... ie reciept details with reference to the engine #. I found this out whilst standing infront of an RTA lady when trying to update details after dropping an RB25 into the Cefiro.... DOH
Luckily i had the receipt still....
ok just got off the phone to the rta, thought id post up my findings for anyone else who needs the info i the future, you just need a receipt with the buyer and sellers details, name address and the date and price that it was bought for, signed by both parties, if you cant get that then a stat dec from the buyer explaining the reasons why you can get or dont have a receipt, the price and date you bought it and then with the stat dec its up to the rta manager whether its accepted or not,
i guess if its not accepted you could pursue it further so yeh its not a lost cause, lucky me
all you have 2 do with the blue slip guys is to just say i just replaced the motor can you check the number and note it on a blue slip then go to the rta and do all the paperwork up there they shouldnt check over the car if you say that
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
