  • Replies 214
Posted Images
Well i made a new set of drivers side seat rails again today and i am still not happy with them.
The first design was custom adj sides mounted to the factory bolt holes, due to the seat having a large lip on the lower front edge i could not get it to side far enough back for me (too tall).
The next one was straight to the floor pan of the car this gave me good height and allowed the seat to slide back heaps but cause the slide sits next to the seat i could not get the seat dead centre with the steering column (10 mm to the right GRRRRR).
So it is back to the drawing board, i am thinking about some square rhs with three nutsert threads in it and three sets of holes in the seat mts to allow some movement back and forth (No adj slides). My only problem is the nutsert threads are only M6, i am a bit worried about there strength.
If anyone has some good pics of their mounts or some ideas that would be very helpful.
Cheers.
Andrew,
I drilled into the lower control arms up front on the cross memebr I think? so as you move the hole to put some bolt it...it pushes the bottom half out.
I had just over -4 camber up front
was wicked!
hurry up Ryan!!
we gotta hit the track together!
I did some thing similar. I only moved the arm up looking for better roll C. I have seen some redrilled out where the cross is for camber as well.
As for camber in mine, I used a big mofo rose joint rod end and nut.
Edited by Noddy
  • 3 weeks later...
Well it has been a while again, but the progress is picking up slowly i have primed and painted the inside in GMH acrylic black, it is the closest thing i could find to matt black. It looks ok and should not rust or reflect any light at me.
I just have to wire it up over the next three days and try and finish inside the car.
Yes I have something running :)
Yes I want to come down but it is the same weekend as the mid year Noosa Hillclimb. :spank:
You should come for a blat up the hill in the november event dunc. its on Nov 13/14, I think its the weekend before the national supersprint, Nov 20/21?
Sorry for the side track Ryan. I like your cage by the way.
Absolutely perfect mate. I will be up for the nationals if I have to bring a push bike. I just need to impose on someone near morgan park to store the car for a week :) send me details as soon as the other weekend is open, I'll be in and I bet Neil will be too.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
