Yo VIC people, project FATLINE has started
  • Replies 104
Rob: thanks mate, yeah, i tried uploading today and it worked :P
Sentric Dancer: stock Mspec body for now, apart from low drift wing (see pic earlier). The only front bar i really like is the Trust GTR bar - same as Merli's. I think it will be hard to source, so maybe in time i will think about it.
Hey there Marcus...
You wouldn't have previously owned an E30 Beemer by the way??? I'm friends with Rohan L, and he was apparently negotiating to buy some wheels off you at one stage....We met b 4 you got the 'line (or am I going off on some idle tangent)
Paul
The covers were acid dipped then painted with oil/fuel resistant high temp paint.
The car's stock apart from the plenum, fmic, exhaust and boost...
155 is pretty much spot on for those mods excluding the plenum.
The plenum has much lower velocity than the standard plenum at lower volumes, and theoritcally should loose power over a standard manifold at low power.... it's when the new turbo goes on and it gets wound up we'll see some results!!!!!
Doc.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
