trust one is not too bad value for money. just need to cut your sump and weld it on. comes with new pick-up too. they are simple but work well. just try not to smash it on a ripple strip!
that pic angle makes it look far worse than it is. judging by that pic it looks like the front diff is below the subframe!
they looks worse than they are in reality. I know of lots on circuit cars and can only think of one I know of that took a hit and was broken. and I know of a couple factory sumps that have been smashed so in that case you never know if a different sump would have survived the hit or not.
lol was that me that hit the trust sump richard? i pulled the sump plug out and cracked the case. all welded back up fine now.
any decent size sump is going to hand below the cross member.
ben we took std sumps down to tugga, but I don't understand why they dont allow sump extensions....its one of the few mods allowed in prod racing up here and fair enough as it is reliability only not performance
I have a trust sump extension as well.
Although it is a bit low, it's the depth and the pick up extension that make it effective. Most track cars in Japan use them and have proved that it is a reliable unit.
If the sump is too close to the ground then may be your r32 is too low...unless you have modified your suspension mounting points.
Edited by 9krpm
We added wings but kept the factory depth on mine so it's level with the x-member.... I haven't hit the track with slicks yet, do you guys think the depth is likely to be a problem? Holds somewhere between 7 and 8 litres from memory with one of the jap baffle kits.
http://i209.photobucket.com/albums/bb146/h...pe/motorin3.jpg
our external oil pump kits are being CNC'd at the moment too...they will be nice. Teamed with the sump is the ultimate 'wet' set-up.
This will be good, where are you putting the pump and when will the kits be available? (no a/c or p/s to worry about). Hopefully I dont need a vipec to run it :D
well wings are ok, but they just give more room for the oil to move away from the pick-up. but with the right type of 1 way trap doors etc they can be made to work pretty well. some people do fall down though by just making sump bigger (wider) and thinking that will help). what you need is that narrow depth like the trust one to keep the oil around the pick-up, but of course you sacrifice clearance for it. ideally you would have a 2 foot long box section off the bottom of the sump that was only 10cm X 10cm with a hose running to the bottom of it as a pick-up! no oil surge ever but you would need to mount the engine about half way up the windscreen height..... could be a problem.
and yes it was yours I was thinking of dundan. just didn't want to name names.. :D
at least it was easily fixed. :P
how does the beaded seat cover you ordered make it fun to drive? I guess when you go into turn 1 a bit too quick and clench hard you might 'accidentally' suck one up the jacksie! nasty.
I have to say apart from that I am a bit excited to see fatz back in a GTR on the track. it's been a long time mate. plus you can actually drive half as good as you talk smack. should give a few people a fright...
how long since you first had your old GTR? must be 5 years now? bit more even?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
