depends what way you wanna go..
coilovers which is more of a suspension package all in 1 but will cost ya around 1k im guessing,.
also adjustable which comes in handy i guess if you wanna change ride height.
or springs, lows, super lows , ultra lows ect.. which will be around $120 a pair + labour.
also if your lowering it a resonable amount probably need a camber kit which i did, only realised after burning through 2sets on the rear in about 6months.
all you've got to do to lower it is:
buy shorter springs
buy firmer shocks to match harder springs
buy front and rear upper control arms or adjustable bushes to fix the camber
buy adjustable traction arm or bushes to fix the bump steer at the rear.
buy roll centre adjusters for the front
modify the rear cradle to have higher arm adjustment to keep the geometery right
then it will be low and as good as new :thumbsup:
or if handling, wheel alignment and tyre wear aren't a issues then just put shorter springs in
79 cents of angle grinder disc, up to a few grand for all the fruit
as has been said, if you just want it lower without adjustment and not worried about handling, then simply get lowered springs and swap them sraight in.
a gooid i dea would also be to get shorter shocks to keep the lowered springs captive(slightly compressed so they dont become unseated (read: fall out))
a better idea is to spend a little bit 1-1.5k and get some descent coilovers which are height adjustable and dampening adjustable, u can adjust the height and the dampening of the shocks.
and as duncan said, u can spend even more to have the car handlings beutifully with correct steering geometry and all
generally 1 inch lower will cost the same as 3-4 inches lower, it all depends on the method
Edited by WrenchesInTheGears
just a couple of tips ... buy your bodykit FIRST if you're going to get one anyway. That way you know how much you can lower the car without scraping etc.
Also secondly, if you're changing suspension do it right and get ALL the crap at the same time ie. springs AND shocks. Labour is expensive so you want to do springs and shocks at the same time eg. bilstein shocks + whiteline springs or just get a coilover kit (shocks come with springs attached to them). Don't forget the camber kits - whiteline sell these too. Camber kits are necessary or once you lower the car you will be chewing through your tyres real quick. Good wheel alignment and camber/castor/toe adjustment after installing new new suspension and lowering the car is a MUST.
you would be suprised as to how much lower the car will be after just getting springs that lower the car 30mm. 2 things happen if you go lower with stock shocks. 1: the ride gets rougher because the springs have to be a higher rate and you also run the risk of the shocks bottoming out which not only ruins the shocks quicker but gives a much harsher ride.
the second thing is that the lower you go the more the camber is affected at the rear and this isn't always fixed with a single camber kit.
Speed bumps , steep driveways , front spoilers , exhaust mufflers/systems , side skirts , crap street handling , defect notices , wrong camber rooted tyres , shit steering , blown light globes , electrical malfunctions , skipping CD's , underbody damage , lots of money and the list goes ---------------------on.
I think what BASHO is trying to say it's best to change the shocks & spings at the same time (adjustable ones preferably) so you dont have to worry about the after affects of cutting or changing the springs to lower your ride. correct me if I'm wrong :)
You got it brother ! I recently bought an R34 GT-t with KingSprings lowers already on (not supelows) and have just replaced the front shockys, one blew.
As I'm actualy only down 20mm from factory I've got away with OE @ $205.57 a corner (front) and they're working fine, I had front and rear wheel align along with castor and camber checks to be sure but any lower and I'd be looking at about $345 a corner for Koni adjustables and all the other shit like camber bolts etc etc.
The one that passenger side that blew can actualy also be put down to 10 years old 80000ks, lovely smooth nearside gutters--and, of course, a spring hight change.
So if you are going for snake belly low you'd best plan a shocky change too and you'll find that you'd probably be better going for coilovers and it'd be cheaper -and better.
Lots of people go for lowering spend shit load of cash doing it and end up changing to coilys later because they just can't get the ride set just the way they want it any other way--been there--done that.
:D
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
