Hello everyone,
It's been a long time since I posted on here last, a lot of people probably don't know who I am (or forgot I even existed :-p) as I've been out of the scene for so long, but I'm finally getting close to getting my line back on the road again.
For those who don't know I've been out of action for a while due to a break in on my car last year, which saw my interior get a bit trashed. Subsequently I had to buy & fix up a cheap hot hatch to get around in before attending to my busted up baby.
While it's been of the road I've fixed up a few other things on it so I can just drive it when I'm done & not have to touch it..... well for a little while anyway. Anyhow, after countless complications I'm finally getting close to completing restoring/fixing up my ride and need a little advice.
One thing that needs fixing is the steering wheel as the looser that tried to steal it managed to put several cuts in the leather so it will need re-wrapping (a new wheel is a bit pricey at over $1k!). So what I would like to know is who people would recommend to do leather work for their car.
I have previously had a quote from Wilshire & if they are considered the best then that's who I'll do it through, though I wouldn't mind be surprised if someone else can do it better.
All opinions welcome, hope to see you all on the road soon.
Cheers, Jared
Edited by J_Red33
https://www.sau.com.au/forums/topic/284027-hey-guys-im-back/
f**k me! Welcome back mate, loooong time no see. Last time I saw you was at a lunch at the Ale House. You'll find things have changed dramatically around here but still got a few of the old timers around.
To answer your question, yes I have heard only good stories about Wilshire, bit on the pricey side but hey, you get what you pay for don't ya?
Hope to see more of ya mate, been tooooo long!
theres a place down south that a mate of mine used to retrim his f100... work was good and pricing was reasonable... ill give him a bell in the morning and get the name for you.
colin at hut-trim in lonsdale.
Hey Jarad good to see your getting it finalised, as Luke mentioned things are very different around here now and you either like it or lump it, there are no more cruises and no more dinners everyone seems self absorbed in beating my post count but dont worry about quality or substance :D
I still have your number so if anything goes down ill keep you in the loop
hey mate, welcome back. Hope your Line is fixed soon and out & about! I will organise a paintball outing shortly so you had better come for some shooting!
I had my wheel done on the S15 by Car Toys, who I later found out just sent it to Willshires and then charge $100 on top of what Willshires chrage. Needless to say I was unimpressed, but the quality of the work was great.
hey jarad, good to see your still kicking around.
if your still around down south, try the retrim shop in mclaren vale. they do alot of leather on boats and cars etc.
it's just off main rd behind the shell petrol station, cant remember the name though.
There is a guy at Seaford up the road from my work that is pretty good ive seen some of his work. Im pretty sure its called pro stitch interior, its just off of seaford road on shearer drive. may be worth a look if your from down south
Resonable close to work, may consider him for mine.
But these 2 are between home and work, and are also closer to home, i will also look at these ones.
I am wanting some R33 GTR seats recovered eventually, also the steering wheel, and almost the rest of the interior :P.
Its called AJ Trim, guys name is Adam. top bloke and does good work too.
If you want his number shoot me a PM
Edited by Jack88
Yeah has been way too long mate, last time I would have seen a number of people was at the Mawson Lakes Hotel. My line got broken into a couple weeks after that gathering.
Go see a place called Winner products. There on main tce at Richmond. I've got some stuff there at the moment getting done.
They're not that too far away from me, as I live in the western suburbs now days. So will definantely check them out, would like to see the quality of their work too. I may also add that I'm thinking I'll get the gear stick cover redone too, so the interior should be looking A1 by the time it's all done.
Hey Jarad good to see your getting it finalised, as Luke mentioned things are very different around here now and you either like it or lump it, there are no more cruises and no more dinners everyone seems self absorbed in beating my post count but dont worry about quality or substance :)
Hey Steve, yeah does sound like things have changed quite a bit, kinda scary!
Will probably be about 6 weeks before the line is on the road (I'm always thinking of other little stuff I can fix/mod), but anything that's happening will be good to know about.
Thanks everyone for the warm rewelcoming & the help so far. Looks like I've got some work to do. :P
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
