Hi All,
The next SAU dyno day is to be held at SST on Sunday the 7th of December, and we'd like anyone from SilviaWA or any other jap import who wants to compete to join us. You will need to complete the form and pay $30 prior to the event to be eligible. We only have limited spaces so get in quick. We're expecting to kick it off at about 10:30. We'll be having a lunch break and will be running a sausage sizzle.
There will be trophies for Highest HP 2L, Highest HP 2.5L and Highest HP 2.6L or greater. There will alos be an exhibition class where we're hoping to have a few very high horsepower cars make an appearance:D
http://www.tnet.com.au/~dantheman/Shooutou...mniform-SST.doc
https://www.sau.com.au/forums/topic/28419-sauwa-dyno-comp-sun-dec-7th-sst/
  • Replies 59
If you have sent you money and form in and your not on this list then PM me:D
Entrants:
Luv DR
Shuto-boy
REP003
MearCat
Jill200SX (SilviaWA)
Yoon Kang
DSTURBD
living backwards
Gavin (japSpec)
B_real (SilviaWA)
ND4SPD
jmp
Bully?
S13 Angel
DR30RS
I will not be running.
I just got a new clutch installed today, canna flog it for a short while....bugga!!!
Also I will come down to support and I will even pay $10 for steve to show me how to adjust my friggin bleed valve (sounds like a bit much, but thats how much I wanna support)
heck I dont mind still paying that $30 if steve will do me a power run later in the week or when I can clock up enough k's on the new clutch
i got sunburnt :cheers:
good to catch up witha few peeps ....... stoopid sun burn tho :(
Thanks for cooking the snaggers Cam ..... big thank you to SST and Paul for organising and the people that came down and supported the event :grouphug:
No probs Niz - farkin hot job it was. I saw quite a bit of sun myself.
Good work by both the postwhore and the SST boys. And thanks to all those who came along.
Paul - you going to post up a full set of results?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
