  • Replies 716
Posted Images
  • 4 weeks later...
  • 3 weeks later...
this may be the reason why there has been not much prgress on the race car
yes its movemeber so you should sponsor me!
http://www.everydayhero.com.au/von_trapp_family_shaggers
anyway time to do something
mother of god i did some work on the shita
just jap ic hoses
front dive shafts in and lubed up ( ohhhh yea)
oil cooler mounted with cable ties ( yea baby)
radiator test fitted ( header tank set up
wirig re- connected
probably another few hours to get the front end done then bolt up the exhaust put some oil in and kick it inthe bitts
Hahahaha yep there is progress.
Front suspension is all bolted up and uprights done, got the rails ground back and ready to take the plasma cutter to them for the drive shaft humps.
Awd box is also sitting there and floor is marked to be cut out
sexual chocolate.
best pic is the blue 31 interior. should put that interior into the GTR for some much needed class.
how many cars you trying to build at once you clown? and half your pics don't work for some reason. photobucket sucks the big one.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
