Hi all,
Ive got a series 2 r33 gtst running with an rb20 remapped ecu. My AAC has been disconnected (was like that when i got it) ive been told this doesnt work with the remapped ecu and is the cause of my idle hunting issues...so was wondering if was one can offer any advice or at least confirm that this is true.
Cheers,
Lucas.
Edited by stolen-gtr
https://www.sau.com.au/forums/topic/284594-r33-gtst-series-2-rb20-remapped-ecu/
Thanks for the responses guys :(
So am i right in saying, basically the short answer is the R32 ecu that i have will give me fail idle unless i get a new Z32 ecu remapped to work with R33? How much is something like that going to cost me?
cheers,
Lucas.
The AAC does work with Remap but as you have R32 ECU you have no VVT , Ive seen some Dodgy Perth tuners ground the VVT so its on full time causing shit Idle and lack top end power. R33s need to use Z32 ECUs with remap.
DOn't waste your time with a Z32 ECU, or even RB20DET ecus
http://www.skylinesaustralia.com/forums/Po...ad-t210097.html
You can buy nistune off their website, nisstune.com it's $440 for R33 ECUs, solder yourself or pay a sparky to do it
thats not nistune, its a remap.
from the nistune website-
Note ECR33 RB25DET Skyline can use Z32 VG30DETT ECU with minor wire swapover
We are thinknig about doing a board for R33 RB25DE/RB25DET but it involves a fair amount of work, and the parts to interface with the existing 84 pin MCU on this ECU. It is a very difficult board to get started on and requires whole new firmware code to be implemented, whilst supporting customers with our existing product line. I will start drafting schematics once Type 5 has been finished and we have got the knock sensing functionality working.
If you are looking for something to get these going then we suggest either using a HCR32 Skyline or Z32 300ZX ECU with a Type 2 board. See our FAQ topics for more information regarding these ECUs.
Your other option, if you really want to use the R33 ECU is to use an emulator with an expensive third party daughter board (pictured above) available from Sam at
www.drdrift.com.au
Cheers guys, i really appreciate the help. Ill be sure to look into this further when i can afford to upgrade my current setup :thumbsup: but for now i guess ill just have to live with the occasional idle hunting.
Thanks again to all who gave their input.
Lucas.
with remap you have to tune every time you do new moods but nisstune can be updated all time
like others said z32 ecu for r33
If you change mods(eg;change to big turbo) you need tune again.
Its same remap and nistune.
nistune updata means change map.
If you go to tune shop for change map you have pay to each time.
nistune saling software and board.
Board is no need emulator but its same remap nissan ecu.
Im using R33 doughter board(not nistune made) and nistune softwear.
nistune is not same power fc , motec , FCONV.
Its same nissan ecu remap.
Thanks for the responses guys ;)
cheers,
Lucas.
No what people are saying is that you can get a good idle with the nistune chipped ECU, you have unplugged the AAC thinking that the chiped ECU can't control i with this isn;t the case, the chipped ECU can control the AAC so plug it in and get a tuner that can do their job.
People were saying that you will lose the VTC with the rb20 32 ECU which is the case, but with the VG30 ecu you will retain the VTC. From what i have heard about the VG30 ecu's is that there are a few pins that have to be swapped though to make it work with the RB25 Loom.
your confused, you need another board that NISTUNE DONT sell, but you can use thier software to to tune it. Sam @ DRDRIFT brings in his own boards and then uses nistune to map it.
Edited by URAS
Do you offer a similar service for rb25det or z32 ecu Trent?
Looking to trailer my car to you when the motor build is finished
Im happy to do the Z32 ecu swap but personally i dont use the high cost r33 boards ( i just use PFC, LINK or HALTECH etc)
Sam @ DRDRiFT is the only reputable shop using the R33 boards, im sure he keeps good stock if you need to go that route.
Are these any z32 ecus? does it matter if its from an auto/manual/turbo/non-turbo? from any particular year?
thanks
thanks
the later the better, as they are a better ecu. turbo or NA no big deal.
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
