i am currently looking around for some ACL heat shielding ( http://www.aclperformance.com.au/prod_heatshield.htm ) but i have not been able to find anyone that sells it other than one listing on ebay (which isn't the size i am after)
Does anyone know of a shop that sells it?
https://www.sau.com.au/forums/topic/285136-acl-heat-shielding/
In WA Auto one got it in for me and the time before that I picked some up from Supercheap .....in Canberra.....hmmm.....try Ruddy.
Actually do you need heat shielding in Canberra?
Edited by juggernaut1
i tried supercheap earlier this week and they didnt have anything.
I need something to shield the abs lines/abs unit/wiring in the corner from the heat off the dump pipe as there isnt much room
Edited by TiTAN
http://www.dci.com.au/
Ring these guys for a dealer to buy from, they are OE suppliers to Holden for heatshield etc and are cheaper than ACL (who coincidently have gone bust according to media today!)
Tim
That DCI place sounds expensive by the looks of it they offer a cad designed specially formed shield i am only after a single sheet i don't need it mass produced.
As a last resort you could try wreckers and hunt around under the bonnet of an XR6 turbo - theres plenty of heat shielding in there.
If you ring them you can buy single sheets from their dealers and they are cheaper than ACL, I actually know because I have actually bought some (unlike yourself it seems) which is why I suggested it!!!
I hope you find someone with stock.....because ACL went broke today http://www.smh.com.au/small-business/car-i...90826-eyq1.html
f**k, time to credit card RB20 pistons/rods/bearings just incase haha... was going to get custom and go ~9:1 comp once i sold the stagea
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
