  • Replies 44
as for driving a 300kw car, unfortunately 400 is the new 200, and like arseholes everyone has one now.
the fact is 300kw is damn fast and there are very very few times you can use more than 300kw.
as for getting it built for $5k as trent said it is possible, and it's not necessarily impossible. But you will need to do stuff the cheap way....which I'm always happy to do:D
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4797301
yeah im after a reliable build, ive been doing a lot of researching and brainstorming aswel tryin spend the money wisely. Had another talk to the workshop that offered me the price but not quite 100% on his 2nd bits, as i have been through that path already. No sunset on the horizon yet, i just wonna spend the money on all the right places guys... :thumbsup:
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4798834
If your slap happy..
RB30 bottem end $100 (or less) Not rebuilt
Holset turbo 2nd hand $500 (HX35 or HX40) use standard manifold
ECU and tuning $2500~3500ish??
Do you see where i'm going with this??
Sure, it wont be pritty, it will take a reasonable amount of abuse and costs will be very low.
..and the best bit, everybodies jaw will hit the floor when you tell them how much it DIDN'T cost!
That will always be priceless!
Be no means the best way of building good power.. but, with some 'out side the box' thinking, do-able.
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4798845
Spot on mate, what is this rebuilding the bottom end shit? just slap the head on the stock 30 bottom end and away you go! Probably pick up a 3540 for 1200, a 2nd hand microtech or wolf for around a thousy, tune set you back 600 or so bucks then injectors and a pump about another thousand. its very doable for that price range, especially if you do the work yourself
the issue there is he has said he wants a RELIABLE build for 300kw and you just cant assure that with a stock 200,000k motor that you haven't even opened.
People have been making waaaaay more than 300kw on stock 30 bottom ends with hundreds of thousands of k's on them!
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4800974
Some people have been lucky enough to make more than 300kw on the stock bottom end and others have not been as fortunate. there is no guarantee that the stock bottom end will hold as is.
my 1st rb26 bottom end let go after a few mths on 362awkw, aust delivered gtr with only 90000km
my recent rb26 also let go after a few mths on 320awkw
both engines were stock so be prepared for the day when it happens, it is inevitable
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4802447
every known mechanical device has a breaking point.
Some engines are just freaks (either way) and live forever or break with no known (or understood) reason.
So, I go straight back to my last statement!
Sure, you can spend large lumps of $$ on an engine that only makes 300kw, and yes it will keep doing that until it is worn out.
or, you can just say 'bugger it' its gonna break sooner or later and save the extra $$ and do it again in 6 months or 6 years time if or when the things goes bang.
So, to answer the question, yes, it is possable. May not be the way I would do it.. or you.. or half the guys on here. But do-able none the less...
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4804270
As PSI said it can be done and mine is an example.
standard bottom rebuilt with new bearings, rings and seals. $800
RB25DE VCT head - $500
oil lines, tensioners, timing belt - $300
RB 25 hiflowed injectors - $350
Z32 AFM - $250
Holset HX35 - $500
Standard manifold modified to take external gate - $350
Custom dump pipe, piping and silicon joiners - $300
coilpacks, pick your brand these days - $400
ECU remapping - $500
Fuel pump - $200
all this costs just short of 4.5g and is the bare bones prices. you will make 300rwkw with these mods and it will be reliable but I wouldn't want to push it much further.
this is a ball tearer of an engine/turbo combo!
this does not count the gearbox you will smash or the expensive clutch. nor will you get 300rwkw to the ground neatly without a mechanical lsd
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4805884
My main concern with a elcheapo rb30 built at 300rwkws would be having it live at the track...might last 10years on the street but could go pop within the first lap on a track...and I dont see the need to have 300rwkws in a car if its only going to see the street.
The OP said he drifted..how much 300rwkw limiter bashing will a stock 30 take? not that much i would say
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4805899
depends, Limiter bashing kills oil pumps and you really dont need to rev a 30 that hard.
setting the limiter to 6300 is fine even for long tracks (not often you see over 230kmph) and for drift you simply use a good oil pump in them not an rb30e item.
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4806286
hey im doing the same thing atm, ive already stripped the rb30e and i reccon i can build a 250rwkw 25/30 for 5grand or under. but im a mechanic and my dads a fitter and turner so we can make so much gear ourselves its just the time factor of making manifolds and cooler pluming and exhaust but itle be done :) i reccon ill have my whole track car going within 6 months. ill keep u posted on how my build is going if u like?
https://www.sau.com.au/forums/topic/285171-5k-300kw/page/2/#findComment-4810570
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
