Just wanting to install a Water/Methanol Injection kit on my RB26 for the purposes of primarily reducing knock.
Only problem is I cant find any decent tuners here in Melbourne who supply a good kit and install/tune the setup.
Can anyone recommend a place?
ask trent at status tuning?
https://www.sau.com.au/forums/topic/285375-watermethanol-injection/
Not in Aus. but isnt BP Ulitimate 98???
In that case you should get a proper tune done instead of trying to reduce your knock levels by using water/meth injection.
Jst wanna say something about bp ultimate, it seems to be inconsistant in its quality as ive filled up twice now with it; the first time it performed well just like v-power that i had my car tuned on.
This second time, about a week ago i filled up with bp and the knocks are going up; not many by about 6-8 at 5000rpm or so
dont know anything about where the fuel comes from or wanna bad mouth anyone but jst giving my experience...im gonna buy a tank of race fuel from autobarn 20litres for 70bux and dilute the tank just to be safe.
-Johnny
it would be reasonable to expect some levels of variance in fuel octane
this would be regardless of what you buy, where you buy it from, and the brand etc
98 fuel is as you would expect, 98 fuel, sure there will be an occasional shit batch here and there
but i think some people really "lock" into a specific brand of 98, its just fuel ?
a knock of 6 to 8 is nothing
if your car is tuned properly it should knock consistently if you follow the oldschool "advance timing till it pings, then back off 2 deg"
so any variance in fuel, air temp etc is nothing to worry about
WMI comes up a fair bit, and a few of us are using it or intend using it, wondering if it wouldn't be a good idea to have a permanent thread on it????
Might answer a few questions before they are asked.
my thoughts too, but i dont know the exact setup. Cat asked me a similar question earlier today so i presume R33-RB26DETT it was from you. Feel free to pm or email me your full setup and car usage.
Thankyou paul, i did read your excellent faq for power fc.
My car was tuned very safely so the 6-8 knock aint gonna hurt anything, im jst one of those paranoid guys who goes overboard with his pride n joy.
Ive jst done a little test with octane booster which ill post in the FI section, see what people make of it.
I don't use anything but BP U98, has never burnt me. It's is refined over here in WA and I think you'll find that most of the other 98's are lesser grade fuels from BP with different additives (there was a big thread in the WA section about it). Shell might be a different story.
I don't see a problem with the guy wanting to run it to be a bit more safer. I've been thinking of doing the same thing when I track the car next year. The intake temp differences around the year we get up here are quite broad. During a summer day on a track i know i would want every precaution method taken.
Absolutely, your the type of person who takes care of his car n dosent want to take a risk even if the protection helps 5% n cost a few dollars....rather than the cheap bastards saying "it'll be right, she'll be right." your wasting your money; the bare minumum approach lolz
methanol injection for the track, nitrous for drag strip, dilution of race fuel or octane booster on a hot day etc
Im even thinking of meth injection in the future as long as the system is reliable.
BTW check out da thread i made on octane booster which i tested
I've been battling with this for some time now....
I am planning to get a pair of Garrett -9 which is the no. one priority at the moment, so money will be tied up there for sure!
My main prob is that i only have at best 95 available and i get knock with the stock ecu@12psi(not sure if 26 ecu has a low octane map), so its a toss up wether to get the water/meth and run it on the stock ecu or buy a pfc and get it tuned to suit the 95, running the -9s
Like u, i just want to be safe, hence the reason of changing the turbos in the first place! Not really aiming for huge rwkw numbers.
Ive done quite a bit of research on water/meth and its seems to be a definitely good "protection" measure especially in your case, as u would have less risk involved because u have the 98 to fall back on in case anything goes wrong with the system, ie. given that u don't tune extremly aggressive (lean mixtures and advanced timing).
Once u can afford it......give it a go :laugh:
Once u can afford it......give it a go :P
I wish you all the best with your car mate, im treatign my car very well right now cos of those stocker ceramic turbos and will, like you be doing a -9 swap soon; not chasing big numbers (anything over 270awkw is good for me)
I hope you checked out my octane booster thread but it seems a good idea is to tune your car for 95oct on the power fc and buy some race fuel for a mix (like 30-50% ratio to pump fuel)
For WMI, i jst dont like an extra system which can fail if you know what i mean (pump failure, fogger failure, tank running dry etc) all these things bug me n i jst want a nice easy fix like the race fuel mix.
Im tryna find out whether you need a liscence to buy it, maybe give some thought to that idea?
ill of coase update you on anything i find out, n every1 else who likes to add safety to their cars.
cheers mate
-Johnny
I checked out that whole additive thing before i settled on the water/meth concept.
Toluene was my first option but just worked out to be far too expensive in the long run... so i could just imagine the cost of race fuel!!!
Well if every thing works out i'll be installing a Coolingmist kit next month, so i'll let u know how it goes.
lolz yeah the toulene mix was in my head before but had a few doubts about it eating away at fuel lines n other engine components due to me driving my car once a week (if that)
love to hear about your WMI, please post a thread up on it n maybe you might jst sway me in that direction.
Ive injected meth before, worked nicely.....whoops but thats a different story lolz
in your type of cases where fuel is a given issue (ie inconsistent) i would strongly reccomend running a remap of the std ecu, we have a few running high 300kw's on them without issues and the benefit is if you do get a batch of crap fuel the knock map will go a long way to saving your ass.
The main usage (but not always) for water meth is actually to get MORE agressive with the tuning, the issue is if the w/m stops working you are left with a fairly hairy issue. If your lucky and have an ecu with relevant GPO or GPI's you can set the warning on the WMI to switch to a low octane map.
Even if you use the system to stop your current knocking issues with water meth the underlying problem is still there if it ever fails to operate. Fix the underlying issue, or be vigilant with WM levels :)
either way the only sytems to use are available from rocket and here is the systems website. http://www.snowperformance.net/
Edited by URAS
    • You'd want to cap off the re-entry back into the dump too. Just something flat that can be held on by the Vband.
    • Thanks for the recap Matt Z. It was a great day out and I know you have said it already, but we couldn’t have done it without the volunteers.
    • Couldn't agree anymore, massive thanks to all that came by, helped out, or those who just wanted to talk cars. You are the community that make this such a great car club. cant wait for what we have planned for the future
    • Looking at the photos, you could easily just drop this pipe and dump into atmosphere  Just 1 or 2 quick hits for data acquisition - if have a heat shield material and/or sheet metal, maybe just use wire/metal cable ties and attach it in a way to deflect heat from melting nearby wires.
    • 2025 PRP GTR Festival - A Massive Thank You from SAU NSW! On behalf of SAU NSW, I want to extend a huge thank you to our incredible committee for all the hard work and dedication behind the scenes. You are the engine that keeps this club running smoothly! (hopefully an RB lol😆) To all our amazing volunteers who helped make the GTR Festival Sydney such a success, thank you for giving your time, energy and sacrificing your weekend sleep-ins. Your efforts did not go unnoticed and were absolutely appreciated by everyone. We also want to give a big shoutout to the workshops, trade stalls, and the awesome VIP's we connected with over the weekend. Your support means the world to us, and we’re so proud to be part of such a passionate automotive scene. We are looking forward to collaborating with you at our future events.  SAU NSW had our marquee up for two full days at GTR Festival, packed with merchandise, a sizzling members BBQ, and a chance to chat with the committee, sign up, and check out some hot Skylines on display from our members. It was incredible seeing so many smiles and genuine conversations, that's what we're all about! SAU NSW is more than just a car club... we’re building a community where you can make friends, share stories, and talk about anything RB related or not. 📸 Please post any cool pics you took at the GTR Festival in this thread! 📸 To our current members, thank you for your ongoing loyalty, and to all our new members... welcome to the family! We’re beyond excited to have you on board! Please ensure you are involved as much as possible within the club, and make the most of our exciting upcoming events. Here’s to more future events, thrilling drives, chill meets and good feeds! Let’s keep building something special. 💪🚗💨 Matt Zoumpoulis, President SAU NSW
