Thank you for electing Luke and Myself to be Events Organisers,
We will do our best to serve the club in way that see us grow from event to event.
We would like to take this opportunity to thank Cara for all the hard work done so far and implore her to keep going with her car shows that she has already organised.
For our first task an SAU:SA dinner is in the works, details following...
When:
9th October @ 7:00PM
Where:
Coopers Ale House
316 Pultney Street,
Adelaide
8223 6433
Membership forms will available on the evening so anyone not yet a club member and interested in becoming one, here's your chance...
https://www.sau.com.au/forums/topic/285710-sausa-dinner-1/
  • Replies 165
Posted Images
Welcome aboard Steve and Luke :D
The dinner sounds like a great opportunity to formally introduce yourselves and get a good old steak/schnitzel into ya belly.
Unfortunately, I will be in Victoria for work that Friday night, so I cannot attend. I look forward, though, to reading/hearing about it upon my return.
:down:
https://www.sau.com.au/forums/topic/285710-sausa-dinner-1/#findComment-4796733
Sorry guys, been napping on the couch but yes, thanks for the responsibility and we hope to serve you all well. Definitely already have some events in the pipeline, some exciting stuff too that I'm sure everyone will want to be a part of. Look forward to seeing most of you on the 11th at the Ale House. I ask though for tentative numbers ASAP as we need to make a booking for ourselves and don't want to be caught short :D
EDIT: Steve I've edited the title and made the thread a sticky so everyone knows :down:
https://www.sau.com.au/forums/topic/285710-sausa-dinner-1/#findComment-4796747
Just a quick change folks.
I've just spoken to Steve and with his consent have edited the 1st post with the dinner date to be advised.
We'll run it past other committee members at the next meeting approx 1 week away and come up with a date that will hopefully suit most peeps......obviously not everyone unfortunately, as things normally go.
https://www.sau.com.au/forums/topic/285710-sausa-dinner-1/#findComment-4796819
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
