Hey guys
Car is 1989 r32 gtst, vg30 turbo, largish front mount, 3 inch straight through exhuast, pod filter, stock BOV
Boost question First,
my 32 gtst, is running 12psi boost from vg30 turbo, (according to boost guage)
i dont think it has a bleed valve . so im just wondering why the boost is so high.
and also if i get a manual boost controller with a bleed valve would i be able to lower the boost or only raise it?
if thats the case how do i lower it?
id like to get a dual stage controller to run 7-8 for low n 12-14 for high.
Clutch question,
when i boost in 1st in the dry it will spin the wheels, when i boost in second in the dry it will usually spin the wheels,
when i boost in 3rd in the dry,(maybe half to 3/4 throttle) it will all of a sudden rev out, asif the clutch is spinning, n it sure doesnt feel like wheel spin.
I found a receibt in the car for the clutch being done a few years ago, the clutch kit itself was $220, so im assuming its standard.
is the clutch freeplay adjustable and how? and also what would you guys rrecommend as a clutch upgrade, i would like something heavy that can take a thrashing, but is ok for street use, willing to spend up to 4-500 hundred for the kit, i guess.
anyone done the clutch themselves before?
do-able with jack stands? or should i save up more n get a place to do it?
And Headlight question.
My headlight connections are abit dodgey, the wires comming to the back of the globes are spilced off an old connecter?
are there late model and early model ehaqdlights? mine is an 89 model, so iw as thinking mayube sum1 put late model headlights in it,
-Thanks
-Alex
Hi mate... I'll take a stab at some of these questions...
I don't know anything about those VG turbos, but I'd guess the wastegate on those could be set at 12 psi? If you got a boost tee, you could turn the boost up or down, I think most of the entry level controllers are good up to around 20psi (give or take - I could be wrong).
You could very easily get a dual stage boost controller, I'd recommend an electronic one and getting it professionally installed and set to 8/12 pounds.
As for clutch, I had mine replaced about 4 months ago with an Exedy OEM replacement (and machined my flywheel - not lightening though), it's a bit bitier than the stock one and I like it, but I've burnt through a fair bit of it already and my car's not a massive powerhouse. Cost around $700-$800 for parts + install if I remember correctly. If you want one that will take a beating, go heavy duty, but expect to add another few hundred on top of that price.
For your headlights if you're pretty handy you might be able to get some new lenghts of wire from any auto shop and run new wiring (even if it's just where the connections are dodgey) and replace the metal tabs/connection points too (might have to go somewhere like dick smith electronics for these parts). A soldering iron/electrical tape/heatshrink tubing will be your friend here.
well actually the guy i bought it off said it was running 10 pound, and a receibt from a service i found in the car also said "Chekced boost, no bleed valve, running 10 psi"
but it definitly gets up to 12 on my calibre boost guage(i think theyre a cheapy) when i boost in 1st second and 3rd, but maybe that guage is abit off and it is running 10
thanks for that info,
what is a boost tee? am i able to reduce the boost lower than wat it is running already without a bleeder? coz i was under the impression that with a boost controller it can only really be increased?
also if i got a pic of my actuator would people be able to ID it? or antying lol
what price would i be looking at foir something like a decent twin plate clutch,
and with the headlights, yeah im not to bad with the soldering.
but are the're late model headlights and early model? or are they al the same?
boost controller of any sort (bleed, manual, electronic) cannot lower the boost lower than the base pressure set by the actuator. if you want lower boost buy a rb25 actuator, if it fits
Yep, any external boost controller will let you raise or lower boost pressure, as mentioned.
Just get a cheap one and install yourself, very easy to do. I'd say replacing the actuator would be harder.
As for the headlights, I googled 'R32 headlights' and this is the first result that came up: http://www.skylinesaustralia.com/forums/R3...ons-t37813.html.
Call some mechanics and get a quote for your clutch, best way.
Any external (electronic?) boost controller will ONLY ALLOW YOU TO RAISE THE BOOST PRESSURE, which was as mentioned previously.
If you want to LOWER then you need an actuator with a lower rated spring.. R33 GTSt is 5psi, R32 GTSt is 10psi..
Replacing the actuator is 2 or 3 bolts. A manual boost Tee is just a ball valve that you put in the wastegate pressure signal hose. An elextronic boost controller is harder to install but easier to use/adjust, requires you to put a solenoid in the boost pressure line and wire into the cabin control unit.
ok thanks for that guys, guess il be after a 33 actuater spring and manual controller, maybe. or i might just leave it how it is if i cant find one easily
D'oh... blonde moment guys, sorry. Yes, the actuator sets your lowest boost pressure. Replace it with an R33 one to get 7 psi (I think?) and then use a manual controller to increase in small amounts from there until you're happy.
mythbusters ahoy!
Use the air gun to blow compressed air approx A ~ B kgcm2 into the hose and make sure the swing valve controller rod operates.
where
HR32 - A = 0.8 and B = 0.9 kgcm2 which is 0.85kgcm2 (average) which is 12.08 psi
BNR32 A = 0.7 and B = 0.8kgmc2 which is 0.75kgcm2 (average) which is 10.66 psi
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
BCNR33 A = 0.79kgcm2 and B = 0.85kgc2m which is 0.82kgcm2 (average) which is 11.6 psi
if someone can find ER34/BNR34 please let me know
i got an r33, in 4th ive hit 9psi is that possible for a stock r33? its got an exhaust thats bout it.
yea, i got a r34 and its only got a fmic and nismo exhaust, and ive hit 9psi aswell, and i dont have a boost controller or anything. i thought i can only hit 7psi?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
