  • Replies 188
Posted Images
  • 2 months later...
race day sunday at wakie - hoping I can crack into the 1.13's!!
I have also aquired a set of slicks....dont know if I'll use them in this race...may wait for a supersprint to get used to them!
  • 4 months later...
Long time between updates...
Raced at wakefield in June - car felt really off power.
I even had a swift Gti pull away from me down the straight.
I only managed a 1.14.3, had brand new semi's too
so took the car to a mates place after it, had 105-110 psi across all four.
after some research and talking to folks, got it to monaco performance just near newcastle - turns out the timing belt had skipped a tooth on the exh cam and put the timing all out. good job it is a non-interference motor. got it all fixed, oil change too, new plugs, back upto 170psi
car feels good once again so have entered a supersprint 2 weeks time just as more a practice run before MRA in october
now I want 1.13's!!
clappa - already done! according to natsift I am 3 seconds quicker - and according to his hand timing he is 15 seconds quicker LOL
ryan - no chance unless I have turbro powahs
I thought you had a hair drier... Oh wait...
  • 3 weeks later...
  • 1 year later...
Update!!!!
Best now is a 1.12.8 at wakie and 1.06.1 at SMP south.
Latest mods are straight through exhaust (no muffler!) and v70a semi slicks.
Bought a second hand adaptronic ecu, loom and map sensor too.
Just dropped car off at DVS tuning to fit it now.
Did a base run before ecu and got 77.6rwkw. When I got the exhaust mod done at mx5 mania it made 92rwkw. Yep, manias reads mega high!!!!
First race for the year is jan 27 for MRA in mx5 challenge
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
