  • Replies 198
Posted Images
Taking a break from motorsports at the moment, until the end of november and then going to start up again, until then, i'm trying to experiment with stuff, heres a few seascapes!
Enjoy!
I think shes European!! Maybe Italian.
Russian or Ukranian, hahaha don’t know where you got that from Sidd hahahaha. Definitely Italian I say! Hahaha.
Yeah no problems, they had some hardcore filter stacking there haha, ND4, CPL, ND8, GND, and another ND4 if I needed it lol. Vignetting all the way from 10mm to 16mm 
Will let you know when I head out again!
Yeah hahaha maybe not Italian, but definitely not Russian or ukranian lol.
Pics turned out alright, I wasn’t really trying to achieve much, didn’t want to kind of take over your work or anything, just snapped a few pics. Some turned out alright although using a wide angle doesn’t help, I needed to get like in her face almost if I wanted some better shots lol, should of taken my 70-200.
I would of moved the flashes around and changed power settings a bit more if It wasn’t so windy and cold! Next time I’ll take more pictures!
Now you know why you need assistants when doing this sorta stuff.. Deff cant do it by yourself.
When you out to do landscape stuff again?
Well I’m heading to the snow this weekend, so probably the weekend after that I might be heading out, you keen to come?
Yeah assistants helped yesterday I tell ya that, all of our gear woulda blown away! Was funny when she was trying to hold the umbrella getting blown away!
The weekend after sounds good ;)
hahahah even i couldn't hold it.. Was funny tho :woot:
lol @ finger chop sidd
well atleast in the other photos i didnt cut her fingers out lol..
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
