  • Replies 328
Guys Just a warning I live in newcastle & work for exhaust company. Now Singleton Has a badass cop. Be very wary of this cop as he has a very bad rep For Caning import drivers with loud exhausts bov & loud intakes & front mounts. He will think Xmas has come early if he sees around 20 or so imports in singo. Hes a total wanker guys. He will even book you if your washer bottle isnt full. My suggestion is totally to avoid singo guys dont mean to put damper on things but just looking out for fellow nissan drivers. Suggestion Morpeth is a good place as it has 2 great pubs good food & even has shops for the girls.
Just a thought have a good one anyways guys
thanks for the warning, but as its been said we have done this for years and never been hassled .
Why are all the cruises and events in Sydney located in rural/less populated areas. What about south western sydney, say like liverpool - campbelltown area?
i think the thing is not everyone want to go on a cruise where we have to stop at a set of lights every 5 mins, things like this one are good because its a decent drive on an awesome road. not all cruises have to be where people can see us driving around the city.
id prefer to go for a drive into the countryside. much nicer than driving in a buit up populated area.
come along and see how good it is. then you will see why we do this one.
Ill try to be their, only if my mate can skip work and come along.
Speaking of which, why is this event on a Thursday, dont you guys work?
also, how long will it take to get from windsor maccas to singleton?
Edited by IM-32-FK
No.
I think you'll be better suited to another cruise rather than this mate.
We do not want to see silly stuff at all.
Aw come on, no silly stuff? I was going to wear a fake afro. I guess I can just wear my doo rag.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
