Hi guys, i think its time for me to let go of my car due to the big move overseas. The car is in pristine condition interior and exterior, it has 80 thousand genuine K's. I've had it serviced with fully synthetic oil every 5 thousand k's. Has new clutch and brake pads fitted. Due to condition and status of car i believe 16,500 is a very small asking price, as will anyone who comes to visit the car.
CAR: 92-93 R32 Gtst type M
Mods:
Apexi adjustable suspension (blue)
Full Nismo Exhaust with 3inch high flow cat and dump pipe
17inch Polished Enkei rims
Blitz BOV
Greddy Air Pod
CAI (cold air intake)
Strut Brace
Custom Oil catch can
Gtr rear spoiler
body kit
Endless brake pads
Daikin heavy duty clutch
full alarm and immobiliser (keyless)
upgraded ecu
Interior:
pivot turbo timer
tinted windows
Pioneer OEL display head unit (mp3)
Jbl 3 way 6 inchers,
4channel amp
Pioneer 12inch in custom made box in boot
AUTOMETER boost gauge
https://www.sau.com.au/forums/topic/28644-93-r32-gtst-type-m-16500/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
