Sau Nsw Oran Park South Track Driver Training Day
  • Replies 389
Posted Images
Yep, as Duncan said, you're in Ben. Others have sent payments through, but as per usual it takes a few days for the payments to appear on the statement for the SAU account.
I knew I was in, I deposited the money about 4mins after the thread was created. Just want to see whom else is attending.
I have a couple of mates outside of sau interested too so waiting for that to open.
How many spots are actually open...
I'll be screwing my motor back together in the next 2 weeks... Like, 1 week before race day... But I'm not sure if I should enter or not in case it breaks?
Hey nick, probably already covered but what is the price for non-members.
$200 bucks will cover it for anybody and everybody my good man. The only real rule is no open-wheelers. I pass because I have fibreglass covering my wheels.
Neil.
I cant make it but my WRX mate from work is keen to come.
Abo, make sure you he rip it up in the last few seccions like our last L2S day out there! Expect a form today from Steve.
Thanks
Paid...!
Couldn't fit my SAU name in the Description so put real name (Ben Taylor) and group 5 for me..
Looking forward to it..
Now seriously, Duncan can I drive your car?!
Haha..
Edited by dunownaskyline
wicked, can't wait for this day
cmon liz pay up!
Entry paid!
will be good to meet you mate, its a hell of a trip down here but should be worth it :)
Paid...!
Haha..
hey if you can handle vtec you can probably handle a stock skyline....but I've got a strict rule that you have to have lost blood working on the car before you can drive it :happy: will be good to see you out there :)
f**k it... Paid.
I'd say Group 4...
Never got a time on OP GP, but I kept climbing up on the ass of other cars when it actually ran... So better to be in Group 4 I think... put us in Group 5 if you want... I'll be running the same setup except on semis (So long as the car runs)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
