Sau Nsw Oran Park South Track Driver Training Day
ive got some water wetter you can have, left overs from the shop,
yeah thats why we're running a flux capacitor in the new car. bloody car has always run hot even with all the changes over the years (overdriven water pump, big radiator etc) but runs about 10o cooler with water than coolant
  • Replies 389
Posted Images
If Stu wants a timer, and what not... Lemme know Stu...
Duncan, need to have a chatsie with you and Brad one day soon... Re setting car up properly for a certain race category...
Strange question... Have you earthed the radiator? Not just through the mounts either... Full earth cable...
PS... It was never really that hot... :(
We rolled in at about 4:30 am Monday and went to work as well, No holiday up here. As you could Imagine it has taken a couple of days to get back on track, and get a clip together. Sara spent a fair bit of time wandering about getting Random bits to string together and some incar as well. The bump in the straight claimed 2 good tires which was very annoying. Semi's reaped a 50.23 according to the time sig on the tape and the slicks pulled a 48.09. I'm not saying there a real official time as the camera a bit of a shake with the slicks on. my fav part is the ducks crossing the track.
Sorry some of the quality isn't quite up there, I trying some different formats for uploading. Suggestions are most welcome.
Ps. Thanks to SAU NSW for putting on a great day, we had a ball and would do it again this weekend if there was enough $$$ in the bank.
http://www.vimeo.com/6942621
You had the Yellow R33 that did the big left tyre lockup into turn one? I've got that in slow motion video. I don't have a lot of other video of your car just a few bits. If you want me to cut you a CD PM me your address. Didn't know you came all the way down from Qld! Wow, what a farewell to OP.
Ps. Thanks to SAU NSW for putting on a great day, we had a ball and would do it again this weekend if there was enough $$ in the bank.
those f**king ducks nearly went in my radiator twice
I almost forgot about the ducks - they were crossing the track at turn one when I came in on one lap, and because they're dark brown I could only just see them. Luckily I wasn't pushing on that lap, the pedal had started to fade the lap before, so I was taking it easy (or easier, anyway).
Ok, so just got an update on the kid that got taken to hospital from the Go Karting that was going on on the North Track.
Had the kid been wearing a cheaper helmet, he would have died.
He has broken his cheek bone in 5 places
Broken Jaw as well.
He was in a coma, and they are removing the drain plug from his brain today.
They are unsure if permanent damage has been sustained.
One of the girls i work with, her cousin was racing in the go karts.
I'll keep updating as I hear.
But wishing him a speedy recovery.
car was much better behaved this time around, i was confident on the brakes where as last time i shit myself when i had to brake as she wanted to swap ends. Still have to sort out light throttle as it wasnt happy, and check reverse and 6th gear selector as there is an issue there, but all in all, big improvement on last time. might be up for the next group up next track day.
btw stu you need to get a timer in the car, I reckon you were getting around there in a pretty decent time...
You should be in the fast group with us. You're quick enough and you'll be surprised how much you improve when your chasing someone quick, ie. Duncan and Neil. (but if you try and imitate what Neil does with that radical in a car you'll end up in a world of trouble, lol)
I was in group 1 on road tyres in the GTR so you'll be fine.
Besides your car looks and sounds fast and we all know that's what really counts :D
yep, although not deliberately. it is solid mounted at the top no rubber bushes
Broken Jaw as well.
really appreciate the update, thanks Chris. We all hope it turns out OK for him, that was among the nastiest things I've seen at the race track, and is exactly why I always race with plenty of metal around me.
haha you were fine.....but i noticed you took some shortcuts only the locals know :D actually you pedalled it damn well considering the street tyres.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
