Hi all
So i went to the car wash this afternoon to rinse my car since the stupid birds decided to poop on it and when i started my car after the wash it was in park and the belts started to squick, I then put the car into drive and it was gone... am i at any sort of danger if i keep driving it till monday so i can take to a mechanic or can i fix this issue myself??? please help ;)
Thank you :(
https://www.sau.com.au/forums/topic/286691-squeaky-belts/
probably because they was water on them they were slipping. would be worth tightening them up a fraction or replacing them, because as the weather gets hotter, if the car sits in the sun during the day, when you start it in the afternoon the belts will have stretched a bit from the heat and will slip even more
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4812035
all the belts were replaced about 2 - 2 1/2 years ago and dont look worn one little bit... I think a bit of tighting will do the magic trick...
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4812511
mate if its just the front belts (3) don't stress out about it! i quick way (not good for the belts though) is just spray them with WD40. I know to tighten one of the belts you have to get over the car and the alternator is one is pretty tricky to get an spanner on. But aside an hour just to be sure to do all three.
good luck :banana:
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4812523
Well i am not chaging the belts yet untill later closer to summer so what i discovered works magically is PAW PAW Ointment lol not only is it good for your body but its also a wonderful thing for the car :(
Nice. But what happens if your battery goes flat or you loose assistance with your steering and drive into a tree?
This is a bit like taking the battery out of a fire alarm so it stops making that annoying "low battery" noise.... :P
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4820978
odds of the belts breaking are very low, but once u start u doing these crappy repairs your skyline will sooner or later become rat sh*t conditions.
Put a side about 2hrs and 100bucks for all 3 belts and change them
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4822072
Just know that if you want anything but dayco belts you will most likely have to wait cuz alot of places dont have them on shelf.. The dayco ones being from repco.
Also got my own trick for the belts, good old petrolium jelly (vasoline) always worked well on my mates old senator.
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4835042
Yeah all these tricks are great.. and everyone keeps a jar of PAWPAW oil in there glovebox..
also if it does break just use an old stocking to replace it....dont worry about this repco rubbish...if ya radiator leaks you can plug it with bubblegum...hubba bubba works best....and if it overheats just pee in the radiator
first rule in the Mechanics for Dummies handbook
If it doesn't move and it should....use WD-40
if it does move and it shouldn't ...use Gaffa tape
keep these 2 things an old pair of stockings, a packet of hubba bubba and a jar of PAWPAW oil in ya glovebox and you will never have a problem... :)
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4835229
Tighten the belts - having slipping belts "might" cause your battery not to charge fully and do some damage to pullies and pre-maturely wear out the belt itself.
If you are still having issues with noise/slipping replace them.
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4853682
Tighten your belts, if there is no adjustment left... then buy new belts.
If your belts were done 2 yrs back and have no visible signs of wear/damage they should be fine for a long time yet.
Do Not lube them.
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4853755
maybe its just me, but isnt squeeling belts mean they are slipping?
why are we lubing up belts that are meant to GRIP the pulleys to make them turn?
very good point, and for a large part you are correct. if a belt is slipping then yes, lubing will make it worse. however if a belt is squealing but not slipping (caused by the belt sticking, kind of like how when you walk on some surfaces your shoes will squeak, or just squealing from when the belt rubs against the pulley as the grooves in the belt slide into the grooves of the pulley) then lubing up will help. but yes in this case, lubing won't help. it would be like putting oil on your brakes to stop them squealing
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4856083
tighten them up starting with the alternator belt. I had really had squealing from my belts and tried to sys out which one it was, dropping the revs with the clutch and brake stops it aswell for some reason, with the aircon off the only thing I could think off having load is the alternator, tightened her up and sqeal begone :). Don't over tighten it though.
I've got new belts on mine and didn't know wtf was causing the squealing (prev owner did belts before purchase).
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4857255
DON'T TIGHTEN YOUR BELT IF THEY HAVE BEEN DONE PROPERLY!!! Too many people do this and when you take the water pump out it will look like someone put a grenade in there, also it puts stress on your bearings in the alternator and then you will have to get new bearings for it, also your Power steering pump will start making a humming noise and you will have to change it. The owner before me had it done to my r33 before i re-built the engine and fixed all that.
Just spray some WD40 on them at them moment because WD40 is not a lubricant ............. silicon spray is a lubricant.
If you want to change the belts and its a r33 turbo model its 4pk 835, 865 and 925 and NA its 4pk 845, 850 and 910. You can get the belts form gates or something for a turbo no problem but the NA's have too be ordered for Nissan or pitwork as there the only company that make these sizes under the same brand name.
https://www.sau.com.au/forums/topic/286691-squeaky-belts/#findComment-4864166
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
