hey guys,
ive decided to import a r33 gtr from japan, and cant decide which broker to use,
ive narrowed it down between these two brokers as they are both based in melbourne
has anyone had any experience with either of these, that can share any thoughts?
im pretty sure both companies are SAU members.
thanks
https://www.sau.com.au/forums/topic/286953-carizma-or-j-spec/
Hey JetBlack, for what its worth we at Carizma are a LMCT who have been in business 12 years, but we believe our biggest advantage is we have our on Compliance workshop and have a stock of standard parts if you do buy a modified car,
Regards
Paul @ Carizma
I believe you wouldnt go wrong with these 2. Call them both up and have a chat, see which makes you more comfortable.
Have you search locally? Unless you're looking for something very specific or rare, maybe you want to see whats available locally before venturing out. Although you might get lucky with the current exchange rate and get something decent for a few grands cheaper.
yeh im looking at taking advantage of our dollar atm so there are some huge savings to be had,
also im not in a huge rush, and there are so many to choose from in japan.
Yeah, patience is one of the most important thing when it comes to buying a car, especially importing.
Because there are always better cars coming up :(
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
