Hopefully tomorrow I will have secured a complete series 2 Stagea manual cradle.
Should solve my problem.
Just need to buy new rear forked shocks. It is a shame I just put in a set of new bilsteins in 200k's old. I am sure someone will want them
  M I K E said:
seems pointless to me? you could run an s14/15 frame and keep your current struts?
I loose $100 on a pair of struts, but gain bigger drive shafts and mechancial lsd
Not too sure if I will break 5 bolt R33 gtst shafts, but not too keen to find out and have to spend more later buying the right gear
  Raysboostin said:
if ur interested i got a pair of stock rs4s rear shocks and springs layin around. u can have cheap if u want em. PM me
Thanks, but I have new bilsteins up front as well, plus need to be height adjustable.
Might sell the complete f & r bilsteins, I find them too stiff. Preferred the Teins I had before
  • 5 months later...
I thought I would post an update.
I had 3 reasons to change my rear to a manual/260rs version
1. My rear cradle was a bit rusty. Could have fixed it but could not be bothered
2. To reduce the rear track by 50mm to match the front end so I can run the same offset wheels front to rear
3. Fit the larger diameter 6x1 bolt drive shafts and mechanical lsd to handle the power upgrades.
So I bought a manual rear end out of a wrecked stagea.
When I got around to changing it over, I discovered that my car, originally a series 2 auto, had the bigger drive shafts.
Basically it is the same as the manual rear end, but is 50mm wider in track.
It had the 6x1 bolt half shafts. The tail shaft is also alot heavy than the standard auto version.
I will also have to check the size if the bearings in the rear hubs as I know GTR's have bigger ones than the gtst version
Not sure if the auto diff is mechanical, but could be?
So I assume this rear end was a factory option?
Have you run your vin through fast before, and checked the options? I know a LSD rear end was an option for the S2 auto's, perhaps this also meant the stronger tail & drive shafts were used to go with it. You may have the LSD option.
  • 2 years later...
  • 2 years later...
  • 5 weeks later...
R34 non hicas craddle and half shafts bolted straight in and wheel alignment without any issues. S1 c34 converted to manual. Wheels that went in were 18x9.5 +12 with a 235/40/18 tyres. Has the slightest amount of poke on the front and rears and near on flush
  • Like 1
  • 1 year later...
So I'm looking to change over to a complete 33gtr rear end. Will there be any issues I run into at all?
Getting a new set of coilovers also so I'll be able to just get rears suit 33gtr.
I'm thinking entire rear so I can fit my wheels without doing flares and while only running -2° camber, changes shafts and diff which was my initial plan anyway.
Car is s1, wheels are 19x10.5+18 SSRs
Excuse my primed bonnet [emoji23]
  On 19/11/2016 at 10:29 AM, KiwiRS4T said:
I got an R32GTR rear - I think you may need to remount the Attessa unit.
The master unit?
How did you go fitting 32gtr rear subframe? Offset spacers or bolt up?
  On 20/11/2016 at 1:14 AM, GroceryZilla said:
The master unit?
Expand
Sorry can't help you with the nitty gritty because I got my local RB guru to do it on a hoist in his workshop. All I know is that the attessa pump etc had to be relocated and I had to chase round for 6 x 1 axles of various lengths (different left and right).
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
