Currently driving an RB25/30 R33 GTS-T with 310 rwkw and 990NM,
stock viscous diff now inadequate for that power.
Need to go a mech LSD, found one salavaged in a diff from an S15. Nismo GT Pro 1.5way.
There's a huge difference in ratios, R33 is 4.11 and the S15 is 3.69.
The car currently does wheel spin quite severely once the GT3076R hammers on.
I'm wondering if the 3.69 is too tall or will it be perfect for my setup.
Certainly can afford to reduce a fair bit of torque.
What sort of rev drop would I expect, say at 70 kph in 4th.
Would it make fuel consumption better or worse as a daily driver.
What about 0-100 kph
Cheers.
yeah I agree 3.9:1 would be as far as I'd go too. 3.7 with the current ratios will have you reaching some astronomical speeds in each gear though. 1st will feel like 2nd almost. punch it in to one of the many drag/gear ratio calculators out there.
I have an s15 with 290rwks with stock diff ratio (3.69) and find its about right with that power........1st gear is useless still but second gear it starts getting traction (depending on air temp) and third is fine.
I also have a Nismo close ratio box so 1st 2nd and 3rd are taller than the stock 6 speed box so they may be similar ratios to your 5 speed.
To give you an idea.....my second gear takes me to around 125 to 130 klm's hr at 8000rpm....and on the dyno my 5th (your 4th) tops out at 225klm's (at 8000rpm) as confirmed by my speedo and also by the dyno chart.
Edited by juggernaut1
S15 manuals are 6spd though aren't they? that would help with the taller final drive ratio.
Personally, I went from the stock 4.3's to 3.9 (auto S13 gears) and it suits rather well. Probably wouldn't want to go any taller though..
What about with the added torque of the 3lt...?
I am after another diff for my 33. I have a 26/30 and C4 auto so want something to swap over for cruising the streets and not reving its arse of and keep the 4.11 for the drags.
Yep ...6 speed as mentioned in my post...I also mentioned that I have taller ratios with the Nismo box....I also run taller aspect ratio tyres.....so overall I have quite tall gearing in the lower gears...which the pissy 2 litre SR has no trouble coping with.
I had a 4.11 diff in another car (changed from 3.54)...sure in gear acceleration was like it was hit up the arse by a truck...... but I was that busy changing gears...I'm sure the mechanical torque advantage was outweighed by the extra time lost in more frequent gear changes.
As mentioned these guys have 3 litre bottom ends ...the torque of which should more than cope with the 3.69 ratio....however.....this would also be subject to what wheel/tyre sizes/apect ratios (read rolling diameter) you are running too.
taller diff ratio = lower numerical diff ratio = higher speeds for each gear.
example 3.69 is a taller diff than say a 4.11.
3.69 will haver higher speeds for each gear than 4.11 ratio and will have higher top speed than the 4.11 if the engine has sufficient torque.
as a broad generalisation bigger engined cars have taller diffs because they have the torque to use the taller diff ratio.....but depending on tyre/wheel diameter
130 kph in 2nd gear ! That's mad.
Good point with the gearboxes, S15 is 6 speed, didn't know that.
Still a hard decision to make without having driven one.
Try before you buy would be nice.
Currently with the 4.11, 1st and 2nd have always been too short for me even with the RB25 with 185 rwkw.
3rd has always been nice and long.
Now, with the 3.0 it still breaks traction heavily in 3rd, say already rolling at 70 kph, then floor it, engines ramps for about 2-3 secs then turbo hammers on, then sideways as hell.
But if throttle is controlled better, accelleration is constant and endless, always seem to run out of road.
So thanks for the comments, I'll stick with my current ratio or maybe a touch taller.
I'm not looking at overtaking the Veyron.
Lol ..stock s15 does over 230klm's .....I want to be at least faster than that.
That's power limited, not revs limited I'm pretty sure. I think when I still had the stock diff in my S14 which is also 3.69:1, it did about 245 at about 6200rpm then backed off lol.
Edited by bradsm87
Yes you are correct - hence with the extra power = acceleration and speed increase. I didn't want to end up being slower with lower ratio diff like what happended with my previous car when swapped to 4.11 diff with twice the rwhp....obviously gearing was too low for the power.......revved out past peak hp in 5th gear at Barbagello.
Esentially my point being if you have the torque use the gearing to your advantage but it depends on what your using your car for too.
Ok I'll see what I can remember (haven't driven the car in months :P)..
RB25 turbo gearbox
3.9:1 diff gears
235/40/18's
2nd gear would get me about 110kmh but that's shifting between 5500-6000rpm (due to power nosing over).
5th gear 3000rpm = 140kmh
5th gear ~2500rpm (I think) = 100kmh
Once my engine is back together, I will have a much better idea as I will be able to wind it out to redline.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
