Need asap a R33 s1/s1.5 stock front bumper for borrow or swap with my fibreglass GTR style one and a "sealed battery". <Battery would be just borrow for pits and thats it as I will put my current one back in.
PM me asap please if you can help.
  • Replies 203
I don't know. Mine is a low maintenance one which apparently won't suffice... Atm I'm going to go back saying the boot is sealed itself so there should be no problems... Plus they came from the factory like that =/
I need pit friendly ones.. My rear left failed right on the far inner edge which is super annoying cause the rest of the tyre is near new and not cheap (dunlop SP sport). I don't really want to change the rear pair just cause of that tiny inner edge..
  • 4 weeks later...
I have
4x legal stockies (2@ 75%, 2@ 60%)
2x legal 18" tyre/rims (90% -235's)
Stock manifold
2x adjustable front spare suspension
1x rear
2x spare rear rotors and brakes - need to be cleaned
And I think it's a series 2 diff? Definately not series 1
China style 3076r
If anyone needs to borrow them/ buy them for the pits, but I won't be home until the 18th of November.
All parts are for an r33 - south of the river
Cheers
Brenton
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Just move to WA and have a couple R32 GTR bits and pieces that may be of interest to those in need:
set of std R32 GTR coilover suspension
I currently have x2 std catalytic convertors
A set of std front pipes
A set of std cam gears
Hope this helps
Does anyone have stock R34 GT-T wheels that I can borrow ? :rolleyes:
I have a set of wheels and tyres, I think they're Nissan Silvia (S14/S15) 16's with legal 205/55R16 or 225/50R16 tyres (not staggered) on some rims. Can't guarantee they will clear the GT-T calipers though.
  • 1 month later...
  • 3 weeks later...
Its been a while and I still have no luck in finding a stock exhaust not even by buying..
Can someone help me or point me out to who might have it?
Also I will always have
Stock RB25 BOV
Stock R34 GTT suspension (lowered springs though ie. too low for stock rims)
cheers
bly
  • 1 month later...
Hey Guys
Dam pits f**ked me over with the Pod Filter and now looking for a Standard Air Box Filter for a R33 to Pass does anyone have one I can buy?
I'll get ya free entry to Metro City aswell :)
email me at [email protected] if ya can help
Cheers
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
