short of writing the facts down on a wooden stake and literally bashing them into your heads with a hammer, I don't think that there is any other way that Gary is going to be able to get the facts into some of your very thick skulls :D
One thing that I really did learn from this thread is how much of a dead set idiot you are.
Are you sure you don't drive a Holden Commodore with a Southern Cross sticker in the back while you wear a straight edged brim hat tilted slightly to the side?
Besides proving my point by being an idiot, what is it that you are trying to achieve by posting the replies you're doing in the thread?
I don't think he even understands the concepts being discussed. Trolling is about all there is to it.
Judging by your off topic replies, once of which is a feeble attempt at a personal attack ([200] that is one of the most pathetic insults I've ever read on SAU), it is in fact the two of you, who are trolling.
I'm merely saying that some people should re read the facts which have been reiterated again and again in the previous 40 odd pages, but are seemingly immune to changing their POV on a particular subject.
I was expecting a reply something along those lines, absolutely pathetic.
Maybe one day you will achieve something in your life and your parents will no longer regret that you weren't just a cum stain on the bed sheets.
LOL.
well once the trolls and continual nay sayers accept the fact that a 13B actually flows 3.9L and revs to 3000RPM before the eccentric shaft, then the thread is finished! until then the debate continues!
What you call fact I say subjective opinion...the length of this thread is evidence of that. But really, shut up man. The debate finished a long time ago...we all got sick of it, even the most argumentative of us. You had your chance for input back then, of which I didn't see much besides you saying who is right and who is wrong. Why try to reignite the fire when the thread is long enough as is? It sure sounds like trolling to me.
Rotor spins at 3000RPM = Yes, no body argues that and was settled a very long time ago.
Flows 3.9 litres...? = It sucks and spits out 3.9l every revolution of the rotory but only spits out 1.3l every combustion cycle
I'll ignore the fact that there are mistakes and say yes, but that is but part of the story. A part which conveniently sets out to discredit the rotary (which is already incredibly flawed anyway).
Everything is relevant to time, everything. The position above totally ignores the time equalising crank/e-shaft and the notion of relative.
This is as smart as quoting torque and not power. Or assuming house prices rise indefinitely because they are high now. Assuming your car is full of petrol so it doesn't need any more again. That not being hungry now means you are okay forever.
Ignoring the arguments of displacement and capacity, the above position ignores time and relatives and doesn't get close to describing how the engine works at a critical point - output. Therefore any conclusions drawn from it are flawed.
It is you who needs to read the thread and understand it.
I have read this entire thread, start to finish, and gary's logic makes more sense than any of yours. To me the simplest way of putting it is that: if a rotary engine does not in fact flow such large amounts of air, then how on earth can they spool such big turbos with ease?
There are 4 seasons to a year, the earth revolves around the sun, humans are mammals, rotaries: revolve 3000rpm, pump out 3.9litres and are 2 stroke. These are all facts. Accept it.
There is nothing magical about a rotary. It does not use any state of the art alien technology. It's combustion technique is unique but by no means state of the art. The fuel it uses is just normal fuel, not any special nuclear fuels. So why in the hell can it produce that much power and use that much fuel if it only pumps 1.3litres? How can it spin a massive T01000000 turbo charger with just 1.3 litres? Use your common sense and logical reasoning people!!!
Mr Skyline Man - i will repost something just for you.
Let’s sum this up in a simple chart to visually explain how this works:
2 stroke engine (up, down) – 1 complete crankshaft revolution.
4 stroke engine (up, down, up, down) – 2 complete crankshaft revolutions.
6 stroke (rotary) engine (up, down, up, down, up, down) – 3 complete crankshaft (eccentric shaft) revolutions.
If its a 2 stroke engine then it only expells 1.3l. If its a 3.9l then its a 6 stroke. So one theory will cancel out the other, its either 2 stroke 1.3l or a 3.9l 6 stroke. As it is quite obvious that its not logical for it to be a 6 stroke and its perfectly plausable to be a 2 stroke then it has to be a 1.3l. If you want to look at it from the rotor's perspective rather than the e-shaft then you need to think of one rotor being one piston that is able to produce 3 operations at once and able to complete three combustion cylces in one rotor revolution.
Don't waste your time guys, you're only posting information that's already in this thread. And they're only asking questions that have already been asked in this thread. All this does is add to the length of it. It doesn't help that they have read the thread something like this:
utter crap
utter crap
utter crap
utter crap
GARY'S POST
utter crap
utter crap
utter crap
GARY's POST
utter crap
utter crap
Mate, there is no 'logic'. There is fact and there is not.
What is your definition of large? It is a totally subject term! The same size as a 2.6L piston engines in a similar fashion? For a 13B? Yes, exactly. Albeit (only) slightly better due to heat. RB26 single turbos can be basically applied to 13Bs. Think T04Z, T51R (extreme) or GT35R!
Many people are still ignoring relatives and time equilisers and only ending up confused (yet arguing based on it LOL).
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
