Hi everyone,
As topic states Is it worth putting R34 GTR turbos on R32 GTR?
I know they are steel wheel , ball bearing turbos so thats a plus. You could also run a bit more boost than 1 bar as well right?
Anyone done this before?
R34 GTR turbos are not steel wheeled.
They are cermic - it is not worth it.
Plenty of people have had them fail, just like all other factory GTR turbos. GTRGeoff in QLD had a low km set fail @ ~1bar as one example - killed the motor.
You play the game of chance @ your own risk.
The R34 N1 turbos are the pick of the litter when it comes to lag of N1 turbos, but I hope you do mean mean R34 N1 turbos not R34 GTR turbos as the R34 GTR are ceramic wheel, except for the R34 GTR N1 and Nur spec which come with the N1 steel wheel turbos
however the stock turbochargers in the BNR34 are larger, the compressor is 0.53a/r vs 0.42a/r (BNR32 and BCNR33)
but the ceramic issue/risk still remains in all family turbochargers
ok i guess what the dude means is swapping the
r32 gtr gt25 turbos
for the
r34 gtr gt28 turbos
if its for a lil tweak it should work but if its for big power you should updrade to a bigger set from garrett or sum
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
