usually after i fill a full tank of fuel in my car, i start it, then revs go up then drop dying off.
to prevent this i usually peddle the revs for a few seconds to combat it then its fine (and wont die). it only does it if after a filling up with a full tank.
so the question is why does it do that? other than that, the car runs fine.
https://www.sau.com.au/forums/topic/288877-r33-s2-dies-after-filling-up-tank/
similar thing happens to my r32 often.
Do u run the tank dry then fill it right up??
before i found what was wrong with mine i had to refill once tank got half empty because my fuel pump sensor level had broken and was a bit dodgy and if the fuel was moving around in the tank it would trick itself and think its empty and car wouldnt receive its fuel becasue the pump would suck it up.
Jaysiin, my s2 does the exact same thing. Usually the symptoms are worse if I "overfill" the tank, i.e I keep putting small amounts of fuel in after the pump has "clicked" a few times.
yes! i always go a few clicks over. but is there more to that reason though?
and pmr33, got a pic for ya...
Edited by Jaysiin
Try filling it up just to when it begins to click, or even a little under and see if that helps?
PMR33, What is that front bar lip / diffuser thing?! I love it! Tell me more?!
Hahaha nice.
Astro boy: Its a set of Vertex canards, front and side. You can see it closer in my pics: http://www.skylinesaustralia.com/forums/Wh...image73393.html
Edited by PM-R33
you really shouldnt fill your tank up above that first click, however i generally do one click after that to make sure its full and the pump isnt tryin to piss me off, if you fill it right up to the brim (alot more than 2 clicks) what can happen is the fuel will run down the breather tube to the charcoal canister if you run one... and providing the canister is hooked up properly, it can cause the car to run like shit, its what destorys charcoal canisters, you'll know when its gone as you get a fuely smell thru out the car
Hahaha nice.
Where can I get a set of these? How much coin would I be looking at?
i belive its something to do with the preasure in the tank, you know when you open it when nearly empty u can hear the preasure some out. i belive its got to do with this as the tank then has to repreasurerise when the car starts check you carbon canistor that has a vac line that goes to the tank thats ment to do something in that scence of preassurising or de press the tank?
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
