Dad & Son Build R32 Gtr
Let Me Drive
hi guys,
been reading this section for ages and now i have enough stuff to show so it would not be like some other build thread that are so old and nothing to show. (we all know how long some of these things take LOL)
Well for a long time me and my dad have been wanting to build a track car that we both can race in and have something to tinker.
so this is what we got as a starting point
A r32 GTR with blown turbos
Then it was the old job of stripping and cleaning
and more cleaning
and some more
then next we pulled the motor and everything else with that
next it was down to Brown Davis to have the cage built oooooooo nice cage lol
so why it was down getting the cage we had them build the seat mount and have them install a racetech wide body seat (to fit our asses in LOL)
now its a game of sanding and filling to get this body right for paint!
  • Replies 181
some more bits and pieces for the car,
these are the light weight rim we had power coated in white (yes we know the rims wont stay white for long LOL)
Sanding is not fun, Every nook and cranny is killing me (if i ever do it again i will get some one else to get it ready for paint) but that comes with building the first
now time to cut the vent holes, i think i might get dad to do this so if he stuffs up i'm not to blame LOL
So the next job and problem if anyone can help? , have spoken to a few people but no one cam come up with an answer.
we are putting an airjack system in the car and with the cage it does no allow for us to mount in the foot well next to the cage due to the peddles so this is our thought
you see there is a space behind the cage in a well in the body which go right though to the floor pan.
we think if we mount there we can wield a plate on the floor pan and wield to the cage it would be suitable to use as a mounting point for the airjack sleeve
what does everyone think?????
Very nice cage! Give the boys at Brown Davis the go ahead and they do exceptional work. Give them a tight as wallet and they are happy to give you a basic, safe and fit for purpose cage like i have.
With regards to air jacks..i know you and your dad are an indutrious bunch but have to ask why? Its only extra weight and extra CA cylinders you need in the truck to get the thing off the ground...and even then i dount the height will be enough to get you in and under...only off the ground enough to change wheels. Better off keeping the car intact and just relying on jacks and fanboys like me who are all too happy toget under your car and get filthy fixing stuff while the drivers tays nice and clean and sips soft drinks :D
well brisby, you see we have time to install them, as well as i would like to not have to use the jack all the time so i thought i would splash out and get them. As for weight what we have cut out at least the weight of the jacks, so no problems there.
well cos we are thinking of doing many races me and dad both would like to have them installed. (i think they are cool LOL)
well a few more thing have come out now, now its just a shell and time for sanding and paint and getting the rest for the gear refurbished!!!!!
or well time for new wheel bearings
thanks dad you did an awesome job on the vents
now time for the sanding!!!!! anyone want to come around and lend me your hands feel free LOL
more updates soon.
thanks for that john will keep every one posted with updates soon
one question does all r32 gtrscome with fined diff cos mine has fins and from what i have been told only v-spec diffs have fins, and if it is am i able to get it shimmed up????
hey guys, need some infomation
we are up to the stage of finding all the suspension part need for the car. so far we have a
lock bar
tein ha coilovers
but everything else is stock !!!!
just wanted to know with say a budget of say 2k what would be the components to buy???
have looked at the just jap stuff and seem alright prices but what do people think any info would be great thanks again
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
