Ok guys ...
clearing out some space to make way for new useless junk :(
There may be more shiet that i find that isnt listed, but whatever is here, ill throw your way free of charge ;)
For just 1.5k flat you will get the following and then some:
[referring to OEM factory stock r34 vspec 2 parts - all in perfect working order no issues guaranteed]
- shocks and springs
- cam cover
- cam gears
- pulleys
- camshafts
- injectors
- front and rear camber arms
- fuel pump
- gtr engine plaque
- fmic + bovs + all piping / hosing
- radiator
- tail lights
- turbos
Random
- brand new trust air filter.
- twin trust filters
- nismo gear knob
Thats all i can think of for now. As i said, if theres anything else i find, ill throw it your way.
Any questions, dont hesitate to PM me
Most PMs have been replied to ... have some kind of 5 minute limit to reply between each pm ...
Would prefer to sell everything but see how things goes ..
Also just found
- nismo oil cap
- vspec 2 ecu
- oem single din pocket
- the turbos have the stock dump pipes attached
- hks ssqv brand new purple fin
- project mu brake pads front and rear with about 80-90% pad left
- random hoses + pipes
pics will be up tonight
All that plus the original post for just 1.5k!!!
Edited by Phantom Snail
are the tail lights complete? (including outer plastic housings)
no they dont have the outter plastic, thats still on the car.
Basically i removed these to fit nismo ones .. so its the light and the wires .. not the housing on the car
mate im keen on the nismo oil cap, are willing to seperate?? is it genuine, pics?
I may separate depending on the interest i get on all parts .. it seems positive and likely at this stage that i may separate ... will wait for further replies to confirm
Yes it is genuine, pictures of most of the stuff will be up tonight
how much for the ssqv??? and where are you at?
Its just the purple fin, not the actual bov.
Im located in Sydney, Fairfield East. Pick up is not a problem.
Ok guys ... as promised, the pictures of most of the items
Please disregard the boxes/packaging that you may see the items in, they are the items i had upgraded to, and the standard oem parts were placed back in the corresponding packages
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
