New radiator in. I accidently ordered the 42mm radiator instead of a 52mm. However its seemed to have worked out so far and ive even been able to keep the fan shroud in there nicely
Also got new shelving for the garage to tidy things up a bit
there is room for more shelves Scottie........dooooooo eeeeettt
Radiator is sweet. Keep cooling fan shroud as it helps keep things........well cool
Its a spare one i have lying around.. Ive got one on the car. May install a dual system if needed down the line
ok good.
Additional oil coolers will certainly help ie diff / transmission cooler etc...
Went for a few short drives today to test out the new radiator and make sure it was working fine. First lap ended up in ditching the car in favour of walking to get more coolant. But after i topped it up it has been fine since.
Also these arrived today
Fark those tyres must have cost a penny or two... I considered buying a pair of 16" wheels once, just to get away with paying for a smaller tyre. So many golds.
$355 each! Was only going to save about $10-$15 each if i went to a smaller rim. As i already had a pair of 17's at home I thought this is the cheapest option for now and would be a good indicator of where the traction is at and if I need to go smaller
Even with the 255/60/15 version of those I'm still baking 3rd lol
Wow! Thats interesting as thats a pretty big side wall. Hopefully these work out a lot better for me. I might give them a few KM of street driving and testing before Powerplay on May 10th.
The thing i like about the 17's is they arent so in your face as a 255/60/15 if you know what I mean? I like to keep a good street look about it and not have 15" steelies on the rear with big ass tread. But for track work I guess it could be alright.
Tune day confirmed tomorrow at 10am! Was going to drive the car down to the Gold Coast for it, however with it being Easter holidays and increased police presence I thinking trailer might be the better option. Cant afford the double fine and double points lol
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
