POWERPLAY: The morning began with a 2am phone alarm [1.5hrs sleep total] Had to do a few minor things to the car before I had to leave. I was driving the car down to Queensland Raceway and it still didnt have the front bar on. I cut some of the bar up to fit the new big intercooler, however didnt guess enough when it came to the piping and it fouled big time. With some creative Zip Tie usage I was able to get it on there well enough for the drive down there and then once there I could just drive without it or look at getting it on there better.
We arrived at QR at 4:50am and orientation/car inspection started at 6am. we were surprised to see we were one on the first 25 cars there so we got into the line super quick and waited till 6am and got the process extremely quick and were at the track come 6:30am, by far a record time in my history. Let the racing begin!!!
We & 3 mates split a garage which got us all pit passes, so we were able to get out onto the track as often as we liked during the cruise sessions. First cruise session was at 8am so we had some time to kill. This was spent setting up the garage with all of our gear, electronics and so forth. I bought the MT streets even though the car was down on power as i really wanted to test them out and see how they went.
Jumped into the first cruise session with just the normal street tyres [265/35/18] to see how they would go as if they were good enough i wasn't going to bother with the MT's. After the first straight I realised they were not going to do at all. I gave them a total of 3 laps before i came in & threw the MT's on.
This was the first time I got to test out the car since getting it back. For the power and boost I was running the car really surprised me, it was more responsive than before and still baked 2nd with ease and also a lot of 3rd. 450hp with the 25/30 definitely felt and ran a lot better than my old rb25 making 450hp which also ran 8 more psi. The torque from the 3 litre really made it a strong 450hp car. It was however still a bit slower than what my car was running previous at 588hp
Anyway time for the MT's Streets!!
I didnt bother letting any air pressure out of them. After the first new hits with these on and getting some warmth into them they preformed perfectly. I cant talk these up enough, it soon became impossible to bake in 2nd let alone 3rd. Each run with these on was 100% grip, the only time I spun the tyres without clutch kicking it was when I had a run from 1st gear at about 5kmph. These stayed on for the rest of the day till i changed back to my road tyres for the drive home.
Here is a few photos that i found of my car on the day. I will have some video up in the coming days also, but i didnt really use the camera much
Here is also a picture of my new fuel system install
Closest race of the day went to a Cobra. Doors to Doors the whole straight
OMG! That 630hp power curve is off its rails.
You are going to shit your pants when that head is re-torqued correctly.
Will you have to get the car retuned once head re-torqued or had Sean said it's all good?
  • 1 month later...
SO been a long time since I've updated this thread and to be honest nothing has happened since. Car is currently sitting in the garage waiting for me to save some coin to fix the head lift problem. Probably still a few months away from getting that sorted as other priorities in life have ppopped up for now. But I WILL be fixing this...
Smallest of updates. Cleaned the rear bar and fitted new pods on, definitely a lot better than the old ones and fit properly
Old
New
  • Like 2
  • 4 weeks later...
Smoked my side indicators last night. still a bit wet so will be lighter once dried.. Should look good when back on the car
Why oh why would you want to people stop looking at indicators....oh wait! They don't anyway! Nevermind ;)
Now sadly the journey has halted...for the time being!...I got to page 20 :(
Love the car! I got scared of the cost of going to the next level of upgrades, but now you have re-lit that fire!
Is it wrong I love and hate your thread at the same time? My car loves you, my wallet wants you sent to a rendition site in Somalia! ;)
Thanks mate! Glad you're enjoying it. Just killing time at the moment to save up some $$ to get it going well again
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
