This is for antonio (wogboy)
it was great meeting up for a chat even if the weather was shite, best of luck with your business too!
feel free to post up progress pics in here if you want once you get your lip kit and coilovers sorted :3some:
https://www.sau.com.au/forums/topic/290613-and-then-there-were-two/
Thank's for that Phil, they look great! And yes he did move it for the photo opp.
G'day Chis, on the boat headin' home now.
Will keep you updated on the progress Phil.
First update, got some Volk GT30's ordered today in Melb 20x10.5 and 20x9.5. Should see them in 6 weeks :thumbsup:
I had that black car apart a few days back. did he show you the button set :thumbsup:
good to see it's in sydney now. still got a ways to go though.
yes Infiniti I believe? any plans to retrofit an infiniti system as the buttons are a bit different in function
antonio, yes please 20" volks gt30 are def the go!, seen plenty of infinitis with them on :(
antonio, yes please 20" volks gt30 are def the go!, seen plenty of infinitis with them on :thumbsup:
given the cost of that unit. nup! he got it because I was sick of looking at it 1.5 yrs later.
units are WAY different anyway. we covered that in person. tv and cams on his are the bugbears.
Those are 2 sexy cars right there... I'm envious. That second pic is cool. The V36s look awesome from the back :(
indeed. give me two weeks and I'll pop a few shots of yours up stripped within an inch of its life :thumbsup:
^Haha... Looking forward to it! Counting the days down actually
Maybe in a few years if I can afford one and once Chris has had a while longer to delve through the multimedia capabilities I will get one. Affordability being the major IF...
Congrats again fellas beautiful cars you have there
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
