I already have a wolf3d V4 in my r32 with a 25det + gcg highflow. Now what is going to be easier to tune and give the better tune overall?
I realise buying a 20det ecu and nistune plus starting the tune from scratch is probably going to creep towards $1000 but I can get at least $500 for the wolf ecu. If I stick with the wolf ecu I will only need 2-3 hours dyno time ($300 ish) to get the tune tidied up (already has been tuned for 220kw run in tune) but it is not going to be as fuel efficient or idle as well, the reason being the stock ecu has fully sequential injection where as the wolf has to run batch mode (fires 2 injectors at once).
What would you guys do for a car in the 240-260kw range that is daily driven? Not to mention I have to go through regency (defect inspection) in the near future so I will need a stock ecu, the 20det ecu with a nistune will help me out here.
Edited by Rolls
https://www.sau.com.au/forums/topic/290801-wolf3d-v4-or-nistune-r32-with-25det/
well if you have to go through the defect inspection thing, then id say the nistune, i have one in mine, loving it.
Yeah that's what I'm thinking, the wolf doesn't offer me any features that make the lack of sequential injection worth it and the fact it is defectable.
You might be better of running a z32 ecu plus nistune so you can take advantage of vvt.
My only gripe with the nistune is that you have no knock lite.
Yeah a knock light is a cool feature. You know whats even cooler?? Auto retard when knock is detected i'd think id rather save my engine than blow it up and know the knock count.
Edited by Crans
Hmm I've dropped the car off at boostworx. Maybe I will go pick it up (they haven't done anything yet) and do some more research and be 100% about what I should be tuning it with and who I should get to do it.
Really is a headf**k finding a good tuner and knowing what ECU to use. Really is hard to sort the good tuners from the bad tuners. Everyone has a different story about what ECU to use as well, like I'm talking 100% completely opposite opinions from well respected people.
Being as I have to go through regency and need the stock ECU I think the nistune really can't be that bad an option to go with though.
Edited by Rolls
uhh i dont remember saying i would rather a knocklite INSTEAD of nistune pulling a bit of timing out, Jus saying it's a handy thing to have diagnosing a problem that you dont know exists is kinda hard.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
