Hi
Anyone free this saturday to spend a couple of hrs with me. I may be coming over from perth to look at buying this M35.
http://www.sinergymotorsports.com.au/thumb...s.php?album=390
I'd need a lift from the airport to sinergy motorsports and back.. I will pay for petrol and lunch!
cheers
Wil
https://www.sau.com.au/forums/topic/290850-adelaide-stagea-potential-buyer/
I wouldnt mind a 260RS! but I gotta get an auto cos wife needs to be able to drive it...
I havent booked the flight yet, car is being inspected by Motacheck today, dealer recommended them - I hope they arent 'affiliated'.
There's usually a flight that arrives around 930am or the next one is just after mid-day, will let yas know cheers!
PM Sent with the details Will (didn't see your thread until now. Sorry)
I have been told that Synergy to actually have pretty good stock.
That Axis kit is not an option from factory for an ARX (as you will see in the PM).
It has been available for a considerable amount time (over a year I think) and $27k is too high IMO.
If I recall correctly, it has Tein suspension, but other than that and the Axis kit, it looks pretty stock to me... although I am confused... Where did the aftermarket screen go?
It was in the rear interior pic, but not in the drivers seat pic.
hmmm.
I was wondering exactly the same...
Looked like one of the "much more useful than OEM" Panasonic units, like mine.
hmmm.
Yep looks like the bose system. Doesn't the screen pop down into the dash?
It has definitely been lowered. The wheels may fill the guards but whats their excuse for the low (ie. non-ARX) ride height?
74000kms is pretty normal. Most freshly imported M35's I've seen are in the 60-80K kms ballpark.
25K seems a little high but then I'm not sure what AR-X's go for...they're definitely a higher spec than the RS and a notch up from the RX too if I remember correctly.
Got them down to 25k, still a premium...
It's advertised as Bose sound system...
Sales dude reckons its standard suspension but because the wheels on arx are higher profile it fills the guards better. :O
Does he realise that while the ARX has 18's as opposed to the RS's 17's, the ARX is also 40mm higher than an RS, RX or Axis?
Definitely check out if it actually is the Bose system. Bose and the standard integrated system look almost identical
Edited by iamhe77
?? I thought the standard integrated system IS Bose? There's another AR-X on carsales that has the same one.
Yeah they've got a silver axis there grade 4C with auction papers. K's are too high for my liking though.
I'm not too keen on the suspension being so low, i've heard teins can be quite stiff.
There are three audio systems.
RS gets the Clarion single DIN unit (which allows for the 3 gauge unit or storage compartment)
The RX and ARX all have the integrated dash, but it can be either the Bose option or standard unit (clarion maybe?)
I believe that the Axis models come standard with Bose... but I may be mistaken.
Edited by iamhe77
Hey Guys
thanks for all the volunteers to help. The car is in some sort of warehouse.
I paid for an inspection done by Motacheck yesterday.
The car isnt quite what i'm looking for so I wont go to adelaide this weekend.
Main thing is the suspension is so low it bottoms out over smallish bumps. Rear is unstable when driving... inside tyre wear on front tyres... in my opinion could have been a car setup for drift... could explain the replaced front bumper and rear tyres had much less tread left than fronts. Everything else about the car is good though I am a bit fussy.
Today I'm bidding on a grade 4.5 ARX with 28,000ks on it!
cheers
Wil
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
