i dont know what it is but these new school swoopy cars just dont do it for me... the 350z, the 370z, the R35 GTR... sure they look nice, but they dont look tough.. not like the old school stuff.. they look too pretty, and i dunno, it just doesnt look like a snappy rwd car, it looks heavy and lethargic, with too many electronic gadgets to make driving/modification any fun.. if i had the choice of this or the original ae86... original all the way.
https://www.sau.com.au/forums/topic/290870-2011-hachi-roku/#findComment-4865859
i don't mind it. but all i think about when i look at it is that it looks like a 911 and a rx7 or rx8 had a baby and this was it.
interesting that it will be a subaru/toyota joint venture on it. since it is using a boxer engine i wonder it the subaru version may come with the option of a having an EJ25 in there
https://www.sau.com.au/forums/topic/290870-2011-hachi-roku/#findComment-4865995
  • 3 months later...
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
