How did you go on the last car with the turbo being so close to the paint? Did it melt anything? I know you had the metal heat shield fitted but did you have any issues? Mine looks to be closer to the tower so i am a little concerned.... I got a blanket/beanie or whatever you call it but not sure how long it will last! :huh:
more pics.. manifold is done.. its a very high quality item from Garage 7. whole lot of trickery has gone into it and every runner is the exact same length. collector is laser cut and a few other little n eat things like the fact that i can install the whole thing using just one spanner. no custom cut down tools needed! excuse the finish... i painted it with VHT flame proof paint for now.. will get it ceramic coated soon. but after this up comign event next weekend
Edited by Simon-S14
That is awesome. That right there is the difference between a $400 manifold and a top quality manifold.
Love this thread. Between your awesome wiring, those engine covers, that manifold, and all the other goodies, this is a great read.
thanks mate.. comments like that make it worth while haha.. we have done some serious hours on this car lately... trying to get it all finished and ready for a hill climb event next weekend (something non drift related!!)
did cooler pipes today, now i can weld no worries but havent had much alloy practice turns out i defo need more prac haha. i designed the pipe work and got Decs from garage 7 to weld it for me after i got frustrated with not being able to pull a decent weld haha.
heres another pic.
its the same car man :P
yeah the manifold burnt the paint off the strut tower... i wrapped and ceramic coated the shit out of it all but still got hot with the hard time i gave it
Yeah minor lapse in brain function there :P i meant new build LOL
Its certainly looking the goods, cant wait to see how it performs... If its anything like your last setup it should be crazy :thumbsup: Its come a long way!!
another solid 7 hours spent on it... been crazy the amount of work that i have put into this along with Decs from Garage 7. got ready to get it all started and straight away as soon as i put oil in it noticed it was leaking like a mofo from the rear main seal... arrrrg thats so annoying! is a brand new seal too and i was carefull putting it on too. so f**k knows what the go there is.
anyway primed it up.. took 2 solid mins and 2 batteries of cranking with plugs out to get oil flowing thro everything and pressure to build, i was worried for a min there. Soon as pressure was up i plugged in the coilpacks and injectors and then went to start it and it fired up straight away! i was shocked haha. needed a tad more fuel to idle smooth and once that was done it starts and idles better then it ever has and its not even tuned! base map is pretty close i reckon haha. Sounds AMAZING!
well.. as it turns out the rear main may not be leaking after all but the rear of the head/cam cover, dripping down thro the bell housing.
another solid day/night of work... have spent pretty much 3pm til 10pm every night including whole days sat and sundays working on it... feeling rather drained and burnt out but its very close now... should be ready for tunes on thursday. So far its promising... sounds f**king unreal!!
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
